Member LiquidBlue Posted April 3, 2009 Member Report Share Posted April 3, 2009 Hi, It is very hard to do thin objects or I am not doing them correctly? I tried to do this bat but I could not do it in 3D-coat, because it was so easy to "make holes" in the wings. I retopo'd it and used a modeler to put the wings on the bat and used merge object in 3D-coat. It would nice to do all the sclupting in 3D-Coat. When I merge it, it has holes anyway. Thanx, for a great program. Mats O. Quote Link to comment Share on other sites More sharing options...
Advanced Member Monsoon Posted April 4, 2009 Advanced Member Report Share Posted April 4, 2009 Hi,It is very hard to do thin objects or I am not doing them correctly? I tried to do this bat but I could not do it in 3D-coat, because it was so easy to "make holes" in the wings. I retopo'd it and used a modeler to put the wings on the bat and used merge object in 3D-coat. It would nice to do all the sclupting in 3D-Coat. When I merge it, it has holes anyway. Thanx, for a great program. Mats O. I would use the filled curves. I've made plenty of thin things with it. Just scale down the curve balls... M Quote Link to comment Share on other sites More sharing options...
Member LiquidBlue Posted April 5, 2009 Author Member Report Share Posted April 5, 2009 I would use the filled curves. I've made plenty of thin things with it. Just scale down the curve balls...M I don't know where they are. Can I ask you for a hint, under which menu/button? Thanx, Cheers Mats O. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 6, 2009 Report Share Posted April 6, 2009 Here's a video: http://screencast.com/t/98zGfy6qSNf Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 6, 2009 Report Share Posted April 6, 2009 And of couse if holes appear try to use bigger resolution. If you are merging object, scale it up. If you are sculpting and see that resolution is not enough, press Inc resolution. Quote Link to comment Share on other sites More sharing options...
Member LiquidBlue Posted April 6, 2009 Author Member Report Share Posted April 6, 2009 Thanx everyone, I appreciate all the answers and all help. Nice video, I did not notice the small combobox before. Cheers, Mats O. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 6, 2009 Report Share Posted April 6, 2009 I did not notice the small combobox before. Yes, hopefully the new interface will make things like that easier to find. Quote Link to comment Share on other sites More sharing options...
Advanced Member renderdemon Posted April 6, 2009 Advanced Member Report Share Posted April 6, 2009 I don't agree much here,thin surfaces are a limitation of the system. It could be cool if the smooth brush could avoid making hole with them. Quote Link to comment Share on other sites More sharing options...
