Advanced Member geo_n Posted June 21, 2020 Advanced Member Report Share Posted June 21, 2020 Very noob question even though I've been using 3dc for more than 10 years Is ther ea way to scale the brush radius but retain the size and orientation of the brush? A quick google search didn't give me good resutls. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 22, 2020 Report Share Posted June 22, 2020 Hi You meaning this option ? In this mode the visible on-screen radius of the brush will be locked. Use this option when you want to change the radius of the brush by simply moving the model backward and forward Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted June 23, 2020 Author Advanced Member Report Share Posted June 23, 2020 Nope. I think what I"m asking doesn't exist in any paint related program Say that's an alpha with the brush size that small. I actually want to scale the brush radius but the alpha should not scale with it and it should tile. Usually the alpha scales with it like the painted part at the bottom of hte sphere. Is there a way to do it? 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 27, 2020 Report Share Posted June 27, 2020 What if you use tiled stencils, or create anew smart material using the alpha texture as depth map (w/uvmap projection) Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted June 30, 2020 Author Advanced Member Report Share Posted June 30, 2020 On 6/27/2020 at 8:48 PM, Carlosan said: What if you use tiled stencils, or create anew smart material using the alpha texture as depth map (w/uvmap projection) That's what I currently do. But brushes are faster and instantaneous to use and no need to keep rotating/moving two things in the viewport Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted June 30, 2020 Advanced Member Report Share Posted June 30, 2020 Yes this is also interested to me how to fill small detail if you need small scale of brush but for large area to fill Quote Link to comment Share on other sites More sharing options...
