[Fixed] major UI issue
Go to solution Solved by AbnRanger,
I figured I would ask this here,
My eyesight isn't that great so I need larger font.
A lot lately when I am using 3dcoat (I am using the latest stable build)
When I right click on a vox or surface layer I get a huge orange box covering most of the options.
I have uninstalled and reinstalled the program and this does not help.
This is so frustrating that If it isn't fixed or I don\t get any help I may have to stop using the program.\
Any help would be essential.
sorry I had to vent, happy new year.
  • Solution
Yeah, I agree. Increasing the font a certain amount can cause some issues. I noticed that a few months ago, so I went back down to a little bit smaller font size. Try the following in order to see if it works and if you like it. I recently proposed to Andrew that this should be the default font/size/style, because it matches closely to what you find in other applications, especially Photoshop. The current default is HUGE and too thin, IMHO.
1) Go to the EDIT menu > click PREFERENCES > THEME tab > click CHOOSE THE UI FONT button at the top of the panel.
2) Select "Yu Gothic UI" with SEMIBOLD font style and 10 -12 as the size
14 hours ago, jammer42777 said:
Thank you, that fixed the core issue, but this is a really nasty bug that needs fixed
Glad that worked. Do you remember what font you used and what size you were trying to use? I will try to report the bug and hopefully Andrew can reproduce > fix it.
  • Carlosan changed the title to [Fixed] major UI issue
