Member jammer42777 Posted June 9, 2023 Member Report Share Posted June 9, 2023 Sadly I am not getting any responses in the discord hello, I had to reformat my HD in order to upgrade to windows 11 And in the process I have to setup the blender applink again. I'm following this tutorial https://3dcoat.com/documentation/manual/interface-and-navigation/app-links/blender-applink/ I have it to the point where Blender is sending fbxs to the indicated direactor but 3dcoat isn't finding them, I need some help with this one. Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 9, 2023 Report Share Posted June 9, 2023 Hi Hope this help Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted June 9, 2023 Author Member Report Share Posted June 9, 2023 (edited) I accidentally ended up deleting my work, (I might have some on a backup drive) but this really isn't the best solution there needs to be a browse button in 3dcoat to tell it where to look, still blender keeps outputting fbx files but 3dcoat can't see them, I can export the meshes from blender just fine but 3dcoat won't see them. I can manually import the meshes from blender to coat but that's about it. are they trying to steer us to the modeling room? Edited June 9, 2023 by jammer42777 Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted June 10, 2023 Advanced Member Report Share Posted June 10, 2023 1 hour ago, jammer42777 said: I accidentally ended up deleting my work, (I might have some on a backup drive) but this really isn't the best solution there needs to be a browse button in 3dcoat to tell it where to look, still blender keeps outputting fbx files but 3dcoat can't see them, I can export the meshes from blender just fine but 3dcoat won't see them. I can manually import the meshes from blender to coat but that's about it. are they trying to steer us to the modeling room? when you import from blender to 3dcoat, the mesh is supppppperrrr tiny, scale up and then apply . you will see what i mean Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted June 10, 2023 Author Member Report Share Posted June 10, 2023 (edited) 10 hours ago, Elemeno said: when you import from blender to 3dcoat, the mesh is supppppperrrr tiny, scale up and then apply . you will see what i mean I checked that zoomed in past the axis but still no dice but thank you for trying. I deleted the 3dcoat directory on my C drive, and restarted 3dcoat, I found another exchange folder in my documents, deleted it and restarted 3dcoat, the exchange folder re popuplated, if I can't fix it I'll post a video later today Edited June 10, 2023 by jammer42777 Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted June 10, 2023 Author Member Report Share Posted June 10, 2023 Apparently blender doesn't want to save my folder output settings. I'm going to contact the blender forums for some help with that first Hopefully I can fix this on my own. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 23, 2023 Report Share Posted June 23, 2023 Blender AppLink updated to be able to exchange data with 3DCoat just from scratch install. So, just install 3DCoat, Blender, follow what 3DCoat tells (easy to follow) and then you may easily drop assets to Blender, including Factures. *** * * Compatibility with Blender 3.6 improved. Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted June 24, 2023 Author Member Report Share Posted June 24, 2023 Thank you, but I did another uninstall and reinstall and didn't see that message I get nothing at all what folder is 3docat looking in for the files? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 24, 2023 Report Share Posted June 24, 2023 Try this steps, it work for me Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted June 24, 2023 Author Member Report Share Posted June 24, 2023 Thank you the reply I've been attempting to follow that, I have managed to get blender to export to: C:\Users\"My user name"\documents\3DC2Blender\ApplinkObjects but 3dcoat will not pick it up. This is after an uninstall and reinstall. Is there a pilgway support team? Perhaps a video call/screenshare? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 24, 2023 Report Share Posted June 24, 2023 Are you logged with admin account ? Applinks was developed by users, not Pilgway. Sorry but it isnt call support for this. Try to help i deleted all folders mentioned, followed the steps and get it working again without any issues. ------------------------------------ - Delete every applink related folder out of my docs. both the app link and 3DC seems to write text files which contain path strings -- if any of these files contain a reference to an old directory either 3DC or blender will automatically recreate that old folder. - Deleting every applink folder includes, in my case: C:\Users\<username>\Documents\3DC2Blender C:\Users\<username>\Documents\3DCoat\Exchange C:\Users\<username>\Documents\AppLinks - Open 3DCoat and close it. This will respawn the 3DC exchange folder. (C:\Users\<username>\Documents\3DCoat\Exchange) - Open Blender and plug in the freshly spawned exchange folder to Blender plugin exchange path. I was able to leave the object / texture empty - Send a Voxel object to 3DC. This will spawn C:\Users\<username>\Documents\3DC2Blender folder. - In 3DC, autopo, automap, and use "export to -> blender". As far as I can tell this will cause 3DC to spawn the C:\Users\<username>\Documents\AppLinks\3D-Coat\Exchange\Blender folder. Choose any fbx name you want. - Export preset should be either Blender Cycles or BlenderAppLink. I used BlenderAppLink - Back in Blender, click the "GetBack" button. This will spawn the object exported from 3DC and hook up the PBR shader! Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted June 24, 2023 Author Member Report Share Posted June 24, 2023 Thank you for your help, I might just manually import the files. You have contributed greatly to the 3dcoat community. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
