Member jammer42777 Posted March 12 Member Report Share Posted March 12 (edited) Hello, I'm working on sculpting my first human head and I'm wondering, what tool would be the easiest to make hair with (that I can texture in the fine details later) I started with the muscle tool, but it looks like it won't work since it's adding too much volume. Is there a better tool? This is what I'm after --Joshua Edited March 12 by jammer42777 Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted March 12 Report Share Posted March 12 This post was recognized by Carlosan! Oleg Shapov was awarded the badge 'Great Support' and 1 points. 5 hours ago, jammer42777 said: what tool would be the easiest to make hair with Hello! Try the new Replicator tool. Only it is still in development and is currently at the testing stage. Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted March 12 Author Member Report Share Posted March 12 10 hours ago, jammer42777 said: Hello, I'm working on sculpting my first human head and I'm wondering, what tool would be the easiest to make hair with (that I can texture in the fine details later) I started with the muscle tool, but it looks like it won't work since it's adding too much volume. Is there a better tool? I will try the replicator as long as it doesn't crash like crazy Thank you --Joshua So this is me frim the future, I had the volume too high for the muscle tool, So it's still decent, Also Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted March 12 Advanced Member Report Share Posted March 12 if you want optimised game hair , hair fibres arent the answer .. you need a couple of flat planes , and a good ahir texture and variate those across your mesh , if you want realistic hair then zbrushes hair fibres or xgen for maya .. blender also has hair particles .. the thing is , use the tool to its best uses and 3dcoat even though it caters for a massive variety of uses , hair isnt one of them Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted March 12 Author Member Report Share Posted March 12 55 minutes ago, Elemeno said: if you want optimised game hair , hair fibres arent the answer .. you need a couple of flat planes , and a good ahir texture and variate those across your mesh , if you want realistic hair then zbrushes hair fibres or xgen for maya .. blender also has hair particles .. the thing is , use the tool to its best uses and 3dcoat even though it caters for a massive variety of uses , hair isnt one of them Actually i just wanted to do the hair blockout just to clarify, I would have the strands textured in painter. Thank you for such a fast response This is what I'm after in coat (whole video) Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted March 12 Reputable Contributor Report Share Posted March 12 You can make your hair pieces using the curve tool Ortho mode is best. Create the curve on a plane. Settings in Curve menu, top of interface. Of course you are not limited to creating one curve. Create the curve, RMB on the curve and select fill with mesh layer. The curve is lived link with the mesh so you can move, transform the control points to further adjust the mesh look. Detach the curve or delete it. Now you can move the mesh, adjust with the pose tool etc. The above is not a tutorial on all the ways to manipulate the curve or using the 3DC tools to manipulate the mesh or making copies. Example not shown for quality but to show a process. Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted March 12 Advanced Member Report Share Posted March 12 use the modelling room .. dont use voxels .. you need one sided polygons , make 3/4 strips , uv them and then copy and paste them on the head Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted March 12 Reputable Contributor Report Share Posted March 12 This post was recognized by Carlosan! digman was awarded the badge 'Great Support' and 1 points. There are many workflows depending upon what the what the user wants. As Elemeno said but if you want thickness and no uving atm. Surface mode not voxels. Of course you can create a uv set too. Create your hair strands in the modeling room, they will show up in the Retopo room as well. Model your all your hair strands as you will have the sculpt model as a guide. Of course you can model thickness with polygons as well.. When modeling thickness, subdivde the stands a few times. you can create the uv seams and un-wrap to the uv set if you so desire. Now you have your hair strands with thickness plus a uv set as well. Import tool, pick from retopo. Choose without vowelizing. The model will be a surface mode model. Give the hair strands some thickness when importing if have they are just "one-sided polygons". I did some subdividing too. No need to subdivide if you subdivided the polygons in the modeling room. You can create the hair strands as above and then hand retopo your one side-polygons on top of those hair stands, they would act as a guide. So Elemeno and I are showing you the various ways of creating the hair strands, the power of 3DCoat. ----------------------------------------------------------------------------------------------------------------- Side note. as Elemeno said, One sided polygons work best for hair stands as Transparently is used to create the hair strands. Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted March 14 Author Member Report Share Posted March 14 So I'm watching a video (just a basic one) it looks like they are just laying planes down into the mesh that are textured, is it really that easy?? Granted it's in maya but I imagine 3d coat is just as capable. Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted March 14 Advanced Member Report Share Posted March 14 1 minute ago, jammer42777 said: So I'm watching a video (just a basic one) it looks like they are just laying planes down into the mesh that are textured, is it really that easy?? Granted it's in maya but I imagine 3d coat is just as capable. it sounds easy but its the placement and material that will make it look natural ... hair is hard ! erm in 3dcoat you can .. but ive always found the modelling tools so hard to use ... maybe use blender for this one 1 Quote Link to comment Share on other sites More sharing options...
Member jammer42777 Posted March 14 Author Member Report Share Posted March 14 Thank you!! Quote Link to comment Share on other sites More sharing options...
