Taros Posted August 13, 2009 Report Share Posted August 13, 2009 Hi, I don't know, if this is already possible in 3DC in the "paint tab" or was mentioned here before. I wish, I could save a 360° turntable animation out of the "paint tab" view. I mean the view, where we do pixelpainting. It would help me to show realtime results of my projects to my clients. It is easier to show them out of 3DC, then to export all information into my animation application and set it up there. This would save time. Be creative Chris Info: Poll for this, if you like the idea. Show the interest for this topic. Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted August 13, 2009 Advanced Member Report Share Posted August 13, 2009 I'm not sure if I understood it. In 3D-Coat v3 you can use "Render" Tab to render a 360° turntable, not only voxel model, but also works with painted model(check on "Render frames sequence"). If there are both voxel model and painted mesh in your workspace, hide voxel object so that it will only render the painted model, otherwise it will render voxel model and painted mesh together. If this is not waht you want, please explain more. Quote Link to comment Share on other sites More sharing options...
Taros Posted August 13, 2009 Author Report Share Posted August 13, 2009 I'm not sure if I understood it.In 3D-Coat v3 you can use "Render" Tab to render a 360° turntable, not only voxel model, but also works with painted model(check on "Render frames sequence"). If there are both voxel model and painted mesh in your workspace, hide voxel object so that it will only render the painted model, otherwise it will render voxel model and painted mesh together. If this is not waht you want, please explain more. Ah ok. But I don't want to have a rendered model in this case. I would like to show a "realtime view turntable" to my clients. At first it is much faster to render realtime turntables and second: if someone needs reatime results, then it is important to have such a function. That's what I mean. Nevertheless, thanx for the info. Chris Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted August 14, 2009 Advanced Member Report Share Posted August 14, 2009 OK, understood. So what you want is a command in 3D-Coat. "Roate camera around one axis automatically"? good request! Add my vote to this request. Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted August 14, 2009 Solution Report Share Posted August 14, 2009 Just turn off AA, set light scattering to zero, amount of rays = 1, AO = 0. You will get the same effect as in paint room except shadows. Quote Link to comment Share on other sites More sharing options...
Taros Posted August 14, 2009 Author Report Share Posted August 14, 2009 Just turn off AA, set light scattering to zero, amount of rays = 1, AO = 0.You will get the same effect as in paint room except shadows. Ah ok, thank you for the tip. Is it possible to set a small menu point for this, which makes it automatically, just to save some time? It could be named: "Render realtime turntable". It's not important, I know, but would be nice. Quote Link to comment Share on other sites More sharing options...
