Advanced Member Juan Carlos Montes Posted August 14, 2009 Advanced Member Report Share Posted August 14, 2009 Andrew I like the new retopo layers but, what if i want to merge one of the layer in to DP and hide the other layer?. or merge retopo layes in to DP so you can have two different materials. for example I did my bear Bear with bear hoodie I retopo the cloth and the face to have in two different material, I export each mesh and import the separate mesh so i can Merge it in DP in part. Dam I so bad Writing in english! I hope you understand my request. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 14, 2009 Report Share Posted August 14, 2009 Andrew I like the new retopo layers but, what if i want to merge one of the layer in to DP and hide the other layer?. or merge retopo layes in to DP so you can have two different materials. for example I did my bear Bear with bear hoodie I retopo the cloth and the face to have in two different material, I export each mesh and import the separate mesh so i can Merge it in DP in part. Dam I so bad Writing in english! I hope you understand my request. What if I will do checker - merge only selected parts in retopo menu? Then you will just select one or several objects and merge them. Then you can delete them if you wish. I think it will solve this request. Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted August 14, 2009 Author Advanced Member Report Share Posted August 14, 2009 What if I will do checker - merge only selected parts in retopo menu?Then you will just select one or several objects and merge them. Then you can delete them if you wish. I think it will solve this request. Yes i think that definitely solve the issue !! Thanks again Andrew. Quote Link to comment Share on other sites More sharing options...
Taros Posted August 14, 2009 Report Share Posted August 14, 2009 What if I will do checker - merge only selected parts in retopo menu?Then you will just select one or several objects and merge them. Then you can delete them if you wish. I think it will solve this request. That is nice. Bot don't forget to do this everywhere in 3DC, where layers are used and where "multiple layer selection" makes sense. "Continuity"... do you remember? Best wishes Chris Quote Link to comment Share on other sites More sharing options...
