Advanced Member splodge Posted January 29, 2010 Advanced Member Report Share Posted January 29, 2010 3D Coat(DX) 3.2 - Vista 64 bit When merging an object for microverts the resulting object is coming out faceted. Example below: Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted January 30, 2010 Contributor Report Share Posted January 30, 2010 3D Coat(DX) 3.2 - Vista 64 bit When merging an object for microverts the resulting object is coming out faceted. Example below: Reproduced. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 30, 2010 Report Share Posted January 30, 2010 set lower resolution for microvertex painting. If microvertex resolution is much bigger then voxel resolution facets will be visible. You may increase mv resolution later when need. Quote Link to comment Share on other sites More sharing options...
Advanced Member splodge Posted January 30, 2010 Author Advanced Member Report Share Posted January 30, 2010 I tried setting a lower mesh resolution in the merge panel but it didn't seem to have any effect. But taking your advice I then decided to try a different approach and increased the voxel model's resolution (Inc Res) to 4x and that fixed the problem. Obviously took much longer to bake but the resulting model was nice and smooth. Quote Link to comment Share on other sites More sharing options...
