    • Thanks for the questions. The tool turned out to be quite complex. I'll make another video.
    • shooting in the dark...  try selecting other padding option on Preferences
    • I am aware of this. For an unknown reason, "3DCoat" loses the OpenGL context after displaying modal dialogs, particularly after displaying the startup "Enter license" dialog. When the code for modal dialogs is commented, then "3DCoat" works as expected.
    • Its okay with a default meshes, and appears on my models from time to time and I want to know what is the reason behind this... Because I cannot see specific issue
    • strange... what if you try with any default model as sphere or head ?
    • is quad only coming to surface mode anytime at all?  it got confirmed abotu 2/3 years ago ... and nothing else?
    • yes, look at the date of the quotes. I was adding this quotes based on your version. Some improvements was done on version 2024 making it more stable.   Hi, let me clarify that "improvement" does not mean "adjustments" unless you give it better features to the existing ones such as new options or changes, if the function or tool is not implemented correctly in one version you cannot decide which adjustments come in one new version.
    • Agreed. Was disappointed to try and run 3DC on Linux Mint 22, and have it crash as soon as trying to import any file.
    • Hi! After going back after painting projection in photoshop I got this weird perforation on texture - dots that have a kind of pattern. What can it be?
    • yes, look at the date of the quotes. I was adding this quotes based on your version. Some improvements was done on version 2024 making it more stable. Spans define the amount of proportional loops After 2 double click over the pink curve, keep pressing the dot with LMB and drag to slide the new edge created to the new postion.     this tool don't save previous states in between sessions, only the curves used to create the mesh Need to Apply the mesh before close the session Or assign the curves to keep working on it
    • Thank You So Very Much!!! Textura is Awesome!
    • Thanks to all the responders but there are things to highlight: the creator of this tool recognizes that (Swept Surface N Geners) was uncomfortable to use and needs to be improved and it is not the first time I need help with this. What came to the fore was that when two double clicks on the pink line made it impossible for the new ring to form, I would log it once after my attempts and now it would be impossible. While there are other examples of which require correct explanation, in other ways I try to use them intuitively and they are usually very tedious.
    • how to add a texture in Blender to my model for support on this request please ask for support on the forum blenderartist.com and then send it to textura to paint on top of my original material  and keep both materials. Once you have the textures generated on Blender export  as .png file format -as example- and import the model (as obj or fbx) into 3DCTextura The export png images can be imported and applied to the model as new layers using the command Textures Manu > Import This video is outdated but the procedure is the same for new versions
    • This tool use 2 guide curves and 2 profiles  Double click command is used to add more edge loop to pink curves (guides) as show in the image below to select the curve use the pick icon command   Use Alt + LMB to rotate the viewport   Meantime for version 2025 the dev team is working in a new engine to make better tools for modeling. If you like can contact the developer of modeling room @Gorbatovsky to ask directly for any issue or feedback.   Sidenote: We offer 30 days trial mode, and the possibility of refund after the purchase day for other 30 days; to give to new users 60 days of time to test the app and know if it fill their needs.
    • Unfortunately, this tool turned out to be inconvenient to use and needs to be improved. Which? Surface Swept 2 or Swept Surface N Geners? I'm using 2022 version. The main reason I decided to purchase the software was to be able to use powerful polygonal surface modeling tools. Can you tell me which ones are the best and how to use them correctly? Thanks
    • This is still the same. I don't understand why retopo room strokes tool is connected to modeling room's selection tool. It would be good to have separate steady stroke options for the tools, or at least a global steady stroke toggle switch in the menus what we could use in these cases as workaround.
