Trying to find a shader like this
Carlosan
Hi all
Im modeling a head and have a little trouble
Highlights
- I tried all the shaders
- Voxel>Highlights is off
- View > Low Smooth Shade
But can get the same light effect like the shader pic attached.
The light over the surface showing the shape without burning spots and facing the camera.
Any help is appreciated :)
post-10142-0-42975100-1359159803_thumb.j
MaCrea Shader Maker created by Taron and is free. You can create basic shaders and export them out as png files. It is a good chance that you can create the shader you need.
No need to install, just unzip and run. Runs both on Windows or Linux. It is a easy program to figure out how to use.
Original post at Zbrush. I have given you the last version he created and uploaded that I know of.
http://www.zbrushcen...l-Creation-Tool
EDIT---- I had a typo, I meant to spell Taron and instead typed Taros... Correction is done...
MaCrea_v015b.exe.zip
WOW WOW AND WOW !! :blink:
TY for sharing this !!!!!!! ;)
cant figure how easy was to make new ones !! :rofl:
  • 2 weeks later...
If you are new for this -like me :rofl: -
add an primitive in voxel room
select any shader named PICMAT-something
RMB Construct new shader
add a shader name
the you need to find the matcap pic that you need to make the shader from
the new shader is created in the folder -the texture used is copied here by 3DC-
C:\...\Documents\3D-CoatV4\Shaders\Custom
take care about the matcap pic size... 4kpics take more time to be loaded
It looks like you could use one of the basic spec shaders with a flat gray png. Now that I've had some luck with shaders, I can likely make one.
  • 1 month later...
Im having some issues with MaCrea. Well its kinda a minor issue but the background around the shear is black and no mater what i do it stays that way. It dosnt change with the shader like in the videos i see. So can some one help?
