A total newbee question about masking
another666
How do I mask of a section of my mesh (in paint room) so it can not be painted on ?
I am working through tuts all over the place but am missing this bit ..
I have read the 3dcoat manual about mask but still do not know how to mask off bits ..
Also when I am using alphas/brushes I sometime need to constrain the axis it move along is there a way to do this, It usually is by holding down the shift key ..
What I need to do is stamp out my brush a few times along the same axis with them evenly spaces and lines up .. is there a way to do this.
Thanks
I think Freeze tool is what you're looking for. It's like masking in ZBrush.
About the second question (from the first post), try entering the E-panel ('e' key by default) and choose "Draw with lines". It allows you to paint with straight strokes. Sorry, I misunderstood.
Thank you ,, I was hoping there was a simple drag out rectangle way :)
http://3d-coat.com/f...36285918616.jpg
How do I stop this ? I just want to print the brush onto each side evenly ?
Thank you for your help
You may want to use the stamp draw mode, or the moveable stamp draw mode
I was using the stamp tool, Ill give the vid you linked a look at
Sorry for all the newbie questions, I am just getting to grips with how it all works .. right now I love 3dcoat and hate it when it does not work how I would like :)
Cheers for the help though
With the Moveable Stamp draw mode, you can still increase/decrease the size on the fly, using the bracket keys [ ]. You can rotate it on the fly, too, using the 9 and 0 keys.
