Milo
Starting again... and can't find the way to switch the navagation menu..
I tried to learn 3d-coat in the past.  I had too many things going on and gave up (I was the problem not coat).  This was in Version 3, I have Version 4 and find all the new tutorials I see going to be very helpful.  I remember back when 4 was coming out that I saw Icons in the navagation bar and a way to switch to text or a hybrid.  Did that get removed or am I really overlooking something obvious?  I tried doing searches on the forum and the V4 PDF but I don't think I am using the right terminology.
Press with LMB over the letter T
Thats just it.  I saw that recommendation in the forum search.  I have no Letter T on my screen. Here is my scren.  I am probably overlooking it.  I took it out of fullscreen but I think I have everything that is at the top.   I figure its right in front of me but I have blinders on.
**EDIT**  I am going through more of the V4 Manual and on Page 88 it talks about Live Clay.  It shows the Live Clay in the surface mode with the tools being located between Surface and Adjust Tools.  It shows a image of everything Collapsed.  They show the T in the manual, they show the T between the little Arrow pointed to the Left with the Brush shape or something on right at the top of the selections.  On my screen there is no T.  I also don't see the LC under surface or Object between Adjust / Commands.  I checked it says I am on the latest build.  It shows V4.00.BETA15A I am running the CUDA 64
Edited by Milo
to get the live clay you got to switch from voxel to surface mode. In your vox tree press the V it will swap to an S
as for the Missing T im stumped.. it seems to be missing from your interface
Well I started with a new Document and chose Surface Mode, THen choose a Sphere.    If I start in Voxel mode I see whats in the picture above.  If I start in the surface mode I get what I added in the edit above.
I also don't see the LC under surface or Object between Adjust / Commands.  I checked it says I am on the latest build.  It shows V4.00.BETA15A I am running the CUDA 64  All I get is Surface/Adjust/Commands.
 When I start with a Voxel I get Voxel/Adjust/Object/Surface/Commands.  If I switch using the V in the Vox tree I get the three Surface/Adjust/Commands  The manual shows LC and Object as well but I don't get that on my screen either and of course no T
Edited by Milo
Well I feel stupid I wasn't on that version.  I even looked at it and in my head put myself on the same version.  Everything seems to be as it should be.  T is there and the other Nav menu items are there. (I need a bigger monitor now).
Everyone who tried to help me thank you!
