Member AlchemistD Posted June 15, 2014 Member Report Share Posted June 15, 2014 A Dragon WIP. Just got into 3DCoat this past week and so far I love it. my new favorite program. 2 Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 15, 2014 Contributor Report Share Posted June 15, 2014 Good start! As a "work in progress" many parts look quite finished. A valuable discipline to learn is to develope your entire form in ways that allow you to work with the fastest tool response by keeping to a low resolution as long as possible, If you intend for your dragon to have a body, it should be created in another volume so that that the volume resolution/response time doesn't inherit the resolution of the head, which would seriously constrain your tool response. Quote Link to comment Share on other sites More sharing options...
Member AlchemistD Posted June 15, 2014 Author Member Report Share Posted June 15, 2014 Thanks. Yeah, still trying to wrap my head around the workflow. I don't understand the relationship between voxels and surface. I used surface mode for all of this model, and when i attempted to switch back to voxels the resolution didn't seem to carry over (?). I'm also not yet sure how to add high levels of detail without creating a processor heavy model. So, yeah, still lots to learn. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 15, 2014 Contributor Report Share Posted June 15, 2014 That's why you must plan your workflow. Voxels use more resources than Surface but permit easy booleans, Surface is lighter on resources so is where most folks wind up after creating a good low res start. But going back to voxels (often for booleans that you hadn't anticipated) invites a blurring of your work unless Res+ is used sufficiently to enable the change without loss of detail. Quote Link to comment Share on other sites More sharing options...
Member AlchemistD Posted June 17, 2014 Author Member Report Share Posted June 17, 2014 Implremented your suggestion and started from Voxels, making better use of the layers as well, struggling with the pose tool a bit now, but getting the hang of things. 2 Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted June 17, 2014 Contributor Report Share Posted June 17, 2014 Superb work! Quote Link to comment Share on other sites More sharing options...
Member AlchemistD Posted June 18, 2014 Author Member Report Share Posted June 18, 2014 Thanks you. I put a little more work in today. Still learning the interface and workflow. 1 Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 18, 2014 Contributor Report Share Posted June 18, 2014 Does the nose ring serve the same function that it does with bulls? Quote Link to comment Share on other sites More sharing options...
Member AlchemistD Posted June 18, 2014 Author Member Report Share Posted June 18, 2014 (edited) Does the nose ring serve the same function that it does with bulls? I think so, it's so they can be led around, right? Edited June 18, 2014 by AlchemistD Quote Link to comment Share on other sites More sharing options...
Member AlchemistD Posted June 20, 2014 Author Member Report Share Posted June 20, 2014 Latest sculpt - skull. Really liking this app. 2 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 20, 2014 Reputable Contributor Report Share Posted June 20, 2014 Great work, thanks for sharing the wip updates... Quote Link to comment Share on other sites More sharing options...
Taros Posted June 30, 2014 Report Share Posted June 30, 2014 Clean work. Looks nice. Quote Link to comment Share on other sites More sharing options...
