V4.5 BETA (experimental)
@ TimmyZDesign: All settings were zero. Thanks for the tip on the Brush view settings.
@ Gary Dave: Thanks, I'll try a new project.
Sculpt Room: I'm Drawing and Extruding onto both surfaces and voxels using completely circular brushes, and the results are oval/stretched. The brushes are being drawn onto smooth surfaces, one of which has little if any curvature on the area I'm drawing on (although there is a rise close by), while the other has a bit of convex curvature and is fairly close to an edge. Or is there any way to tell a brush to sample the normals over a tighter/smaller area?
Win7 64
4.5.39
Replace geometry in paint room just saved me!!!
Thank you so much for this.
@Traby
RMB over the model layer
convert To Global Space
Help ?
post-10142-0-10992800-1464076354_thumb.j
To Global Space
Sets the VoxTree objects space to be set to world space, at 0 on X, Y & Z axes.
@Traby
Help ?
Perfect, thanks. Does exactly what I was looking for. Sorry for what seemed like a noob question.
I find I ask "noob questions" all the time. 3D-Coat has so many possible uses that I encounter things I have never done before.
- Bake->Update paint mesh with retopo mesh
- Fixed "Edit projetion in ext editor" issue in vertically aligned window.
- "Ignore back faces" works for Move tool in surface mode.
- nice bewel in primitives with "sector" option
  • Like 3
Thank you very much for the support.
Both links refer to 39 version in the first page of this thread.
I downloaded from here http://3dcoat.com/files/3d-Coat-V4_5-40-64.exe
1) Issue with paint and projection solved , much appreciated.
Edited by Michaelgdrs
I know you have been around the block a few times but is that the voxel layer poking through?
Can someone please verify that AO is working?
I bake AO from Paint --> Textures --> Calculate Occlution and allthough it does calculates it , it gives up nothing as a result.
Edit
Did some tests , Sphere mode  is working , semisphere has the issue on my side.
AO is working, but cant select cpu or openCL, and post smoothing steps anymore
No smouth value either , at least on my side.
Edit
It should work fine.
Please more information:
1. Version 3D Coat
2. The resolution textures
3. Model graphics card
4. Operating system
Since version 3D Coat 4.5.38, AO calculated entirely on the GPU using shaders, no choice between OpenCL and GPU.
Unistalled and re installed.
Everything works fine now.
Much appreciated for the reply.
Now all OS builds are included in Google Drive when they are available. Link is in the original post, just above the direct download links for each OS. Also, link is below.
Google drive mirror (Now with all OS builds)
Mac OS X [4.5.40]: Crashes when switching from surface to voxel mode when vertex painted or with pbr materials.
Repeatable/ Consistent
osx 10.8.5
NVIDIA GeForce 9400
p.s any application setting advise for older macs ?
Performance on screen become instantly laggy  when vertex paint is applied.
4.1 works like a dream on 10.6.8
What's wrong with the move brush in the sculpt room?  I'm getting a flipping effect, like I can see the normal of the brush rolling around as I pull the mesh, and the fall off is totally messed up, like noise.  Some points move the way I'm pulling, and others move in the opposite direction.
It's in 4.5.40 and some older betas, not sure how far back it goes.
GL and DX versions do this, in voxel and surface modes.
windows 10
Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Ram: 32.0GB
64-bit OS, x64-based processor
GeForce GTX 760(192bit)
Edited by GabeM
Brush settings "E"
Ignore Back faces is on ?
and related video
Yes that was it, thank you.
Do , please , blend modes to layers switched the mouse wheel . So , as it is - very uncomfortable . And even if the mouse sticks to take her out of the window while holding down the button . This problem exists with older versions
1. Version 3D Coat
4. Operating system
I had an issue with AO calculations: sphere - did no visible results, hemisphere+sphere - exploded my model after calc. I've tested several times, then I restarted 3dcoat and AO calculations worked fine. Very strange.
My specs are: 3dcoat 4.5.40 x64, 1k texture, gtx780ti, win 7 x64.
Why post smoothing steps were removed? Very usefull feature. I used it for draft AO generation, like a preview before high quality baking, very time consuming. Also, it was a good looking dirt texture mask =)
