V4.5 BETA (experimental)
3DC 4.5.05 crashes all the time when I turn on realtime render in render room. All four versions of 3DC crash - DX64, DX64CUDA, GL64, GL64CUDA. My video card is Nvidia GTX 660Ti. It crashes even without any model loaded. I start 3DC, go to render room, check in realtime render - crash. I have sent a bug report.
Edit: I have found that it crashes when I have 'Use Panorama as Environment' in render room checked in.
Edited by Vipera
Realtime render works fine here too
you got crashes using other exr or hdri panoramas ?
All panoramas from 3DC list and any other .hdr or .exr file cause crash. I have not had such problem in previous versions of 3DC.
Edited by Vipera
I want to bump up the question with the difference of shadows in DX vs GL versions in render room, realtime render. digman had the same problem in Linux version early.
I am having very different result for shadows in Render room in 3DC GL version to compare with 3DC DX. Here is the realtime render of  GL version (please note the shadow artifacts in center part of the object):
Here is the DX version. Everything looks fine:
My video card is GeForce GTX 660Ti, Driver version 347.88
I upload this gun model so you can test it.
Future_gun_assembled.zip
About realtime render crash reproduce this mantis issue please. It should be the same problem:
http://3d-coat.com/mantis/view.php?id=1945
It is not the same problem. It is different. I have reported it yesterday. http://3d-coat.com/mantis/view.php?id=1948
Edited by Vipera
