Member 3DTutorial Posted May 4, 2015 Member Report Share Posted May 4, 2015 Hi Guys, I'm working on a complex model (sorry I'm unable to show it due to NDA) but here is my problem. I need to remove some areas using the cutoff tool -- that's not a problem. However, some of the areas that I need to remove are very hard to reach, so I need to hide areas of the geometry using the hide tool... again... no problem. Ok, so now I can use the cutoff tool to remove the unwanted areas of the mesh... ok, all that works fine. Now that I'm done I use unhide all command to bring back the geometry that I had hidden previously but when I do this, it also brings back the areas which I just removed using the cutoff tool... which isn't want I want. I want the areas that I remove with the cutoff tool to be gone. So how do I get around this? Any ideas? Cheers, Joe Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 4, 2015 Report Share Posted May 4, 2015 Hi Are you referring to this bug ? 0001668: Delete Hide is not working Quote Link to comment Share on other sites More sharing options...
Member 3DTutorial Posted May 4, 2015 Author Member Report Share Posted May 4, 2015 Hi Carlosan, I'm not entirely sure... but I don't think so. To better try and explain what I want to do let me attempt to simplify.... 1. Hide areas of mesh with hide tool (I'm doing this so that I don't destroy certain areas of mesh) 2. On remaining non-hidden areas of mesh, remove specific areas using Cutoff tool (in my case I am using to make holes in mesh). 3. Unhide hidden areas of mesh using unhide all command. Result... when mesh is unhidden areas that I had removed using Cutoff tool return. Hope this makes sense. Cheers, Joe Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 4, 2015 Contributor Report Share Posted May 4, 2015 Looks like a new bug: 'Deleted geometry restored with "Unhide All" command which acts like Undo. Quote Link to comment Share on other sites More sharing options...
Member 3DTutorial Posted May 4, 2015 Author Member Report Share Posted May 4, 2015 Looks like a new bug: 'Deleted geometry restored with "Unhide All" command which acts like Undo. Oh dear, I was afraid of that. Is there anyway that I can follow/track this bug.... so that I can see if it gets fixed? This is somewhat of a showstopper for me :-( Cheers, Joe Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 4, 2015 Contributor Report Share Posted May 4, 2015 Send your file to support@3D-Coat.com. Usual practice is to post it on Mantis at http://3d-coat.com/mantis/my_view_page.php but that involves registration, etc and this seems more urgent. Quote Link to comment Share on other sites More sharing options...
Member 3DTutorial Posted May 4, 2015 Author Member Report Share Posted May 4, 2015 Thanks Tony Nemo -- I will do that ! Cheers, Joe Quote Link to comment Share on other sites More sharing options...
Member Solution 3DTutorial Posted May 4, 2015 Author Member Solution Report Share Posted May 4, 2015 UPDATE - PROBLEM SOLVED !!! Problem Solved -- this error was entirely my fault. I have a few old versions of 3D coat on my machine and it looks like I mistakenly ran an older build. When I ran version 4.0.03 - things did NOT work properly. However.... Once I ran build 4.1.17 everything worked as expected. Sorry.... just a simple case of user error. My apologies for the confusion. Thanks for helping me out with this, I appreciate it. Cheers, Joe Quote Link to comment Share on other sites More sharing options...
