Contributor Tony Nemo Posted May 10, 2015 Contributor Share Posted May 10, 2015 Although I did not test this in Surface mode it will probably result in the same behaviour. The image makes alterations to the model (except Primitives) and even cutoff doesn't work until the image is closed (and a ghost of it remains in the view). I posted this on Mantis. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 10, 2015 Reputable Contributor Share Posted May 10, 2015 You have to close the panel/gizmo or 3D Coat blocks you from doing any editing/work on the model. While the gizmo is active, you are in Image Plane SETUP mode. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 11, 2015 Author Contributor Share Posted May 11, 2015 Thanks, it was driving me bonkers. Perhaps I should stay out of Mantis. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 11, 2015 Share Posted May 11, 2015 Hi Tony Could i change this status to knowledge ? ty http://3d-coat.com/mantis/view.php?id=1859 Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 12, 2015 Author Contributor Share Posted May 12, 2015 Please do! Thanks! Quote Link to comment Share on other sites More sharing options...
