Advanced Member blade33ru Posted February 11, 2016 Advanced Member Report Share Posted February 11, 2016 I have a model exported form retopo at low res which i have fully textured with 20 layers or so. Now i have another paint object, the same model with same UVs exported with extra subdivisions into the painr room. How can i get it to pick up the textures which already exist. trip importing and exporting textures but seems to apply to the original model. i delete original model and still no love. help! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 11, 2016 Reputable Contributor Report Share Posted February 11, 2016 (edited) I would say use the texture baking tool in the paint room but it as not been updated to the new PBR standard as of yet... Normally you would bake the textures from the low polygon with textures to your extra subdivision model using the texture baking tool in the paint room. Most of time it is other way around, In the paint room you would bake (Texture Baking Tool) from the high to the low but in your case you added extra subdivision and now need the textures from the low baked to the high... I add a will a link to this thread at the beta forum again asking to update the Texture baking tool to PBR standards. Edited February 11, 2016 by digman Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 11, 2016 Report Share Posted February 11, 2016 Try to bake using Retopo -> Bake with NM (don't use texture baking tool), it should work for this purpose. You just need to hide all voxel objects and remain only paint objects. Voxel objects have bigger priory over paint objects. Texture baking tool is too old and much less controllable. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 11, 2016 Reputable Contributor Report Share Posted February 11, 2016 Try to bake using Retopo -> Bake with NM (don't use texture baking tool), it should work for this purpose. You just need to hide all voxel objects and remain only paint objects. Voxel objects have bigger priory over paint objects. Texture baking tool is too old and much less controllable. Older yes but with a little loving tender care it could be most useful ... 1 Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted February 11, 2016 Contributor Report Share Posted February 11, 2016 Done it with both ways several times and both ways work great. I must agree though that texture baking indeed needs little loving tender as my good friend David said. Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution blade33ru Posted February 11, 2016 Author Advanced Member Solution Report Share Posted February 11, 2016 (edited) never mind..IT WORKS..very very nice thanks Edited February 11, 2016 by blade33ru Quote Link to comment Share on other sites More sharing options...
