Contributor Malo Posted July 8, 2016 Contributor Report Share Posted July 8, 2016 Hi Is there a way to use the Cutoff Tool and a Stencil in Surface Mode? As far as i see, i could do that only in Voxel Mode but not in Surface Mode. Any sugestions or help? Is that a Bug? Cheers Malo Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 8, 2016 Report Share Posted July 8, 2016 A bug or a feature request 1 Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted July 10, 2016 Author Contributor Report Share Posted July 10, 2016 Thanks Carlosan. Mantis is open. http://3dcoat.com/mantis/view.php?id=2147 Please add your +1 if anybody is interested in this. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted July 10, 2016 Contributor Report Share Posted July 10, 2016 I just tried both in Surface mode and they both worked (4.7.06). Wassup? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 10, 2016 Report Share Posted July 10, 2016 Shift + M = add surface cube Stencil = select one and keep it on over the syrface model Select cutoff tool with circle brush perform cuttoff The cuttoff tool works as no stencil is on use. ---------------------------------------------- Same test using voxel mode works fine Quote Link to comment Share on other sites More sharing options...
