How to choose the baking side?
Wasili
Is there any way to choose the other side of retopology for baking? I copied the right side of the jacket to the left and I need to bake the left side but by default the bake is right. Is there any way to choose the other side? That's what I'm doing   http://take.ms/f7JjI
One option will be to split the retopology islands in groups and use this option.
Another is to hide islands and perform 2 bakes then merge.
* Is a workaround because islands are the same but overlapped
Pretty interesting use-case scenario, I've done something similar to this in the past, except I could hide bits of the sculpt, whereas I think in your example you'd have a hard time doing that.
I could be miss-remembering, but I had a super super dense monster model, 3 arms on each side and my poor laptop was struggling big time, so I ended up removing 3 of the arms from one side of the sculpt to get my frame rate up, and copying their retopo UV's onto the side that had the mesh. Maybe I got lucky with the left/right and I could have ended up with a blank bake.
I think I understood how this can be done. Is there any chance to take a unwrap from below and put it on top? If I can do this then after the application all this should be baked as needed   http://take.ms/lmGHh
5 hours ago, Gary Dave said:
Довольно интересный сценарий использования, я сделал что-то похожее на это в прошлом, за исключением того, что я мог скрывать кусочки лепты, тогда как я думаю, что в вашем примере вам будет трудно это сделать.
Я мог бы забыть, но у меня была супер-суперплотная модель монстров, по 3 оружия на каждой стороне, а мой плохой ноутбук изо дня в день боролся, поэтому я удалил 3 руки с одной стороны скульптуры, чтобы получить мою рамку повышать скорость и копировать их ретро-УФ-излучение на сторону, имеющую сетку. Может быть, мне повезло с левым / правым, и я мог бы закончить пустым выпеком.
I would just understand how the program chooses which side will bake. There are two sides, but the wrong side is baked )
You can select all the faces of the Retopo mesh > SELECTED section of the Tool Panel, choose FLIP FACES.
