Daniel Aubert
[Solved] Exported Normal Map Issue
Hello!
I made this model highpoly in Blender, exported to 3DCoat, retopologised it, unwrapped it, and painted on it. But when I exported the obj back to Blender it had one problem: normal map is wierd with the seams showing, like if each island were recieving different lighting. And the normal map is the only texture that had this problem; albedo and roughness are working just fine. This may be something I am doing wrong, cause I am new to 3DC, so I would be very glad if anyone could help.
Here are some screenshots:
a. The model working fine on 3DC, with normals working.
b. In Blender the normal is not good. And it is not related to the uv coordinates, because the seams are in the correct place, but each island is behaving differently to light.
c. Here you can see how the map is on the surface.
d. This is the normal map - world-space
e. This is the normal map - tangent-space (both have the same problem)
Thanks in advance!!
Hello
Looks as Y channel inverted.
Do you have Export Constructor actived ?
On 12/15/2018 at 10:49 AM, Carlosan said:
Hello
Did not work. Even tried changing the preset to unreal, but made no difference...
Normal map
For a normal map you can separate the RGB color channels and invert just the red and the green channels. Like in the image below.
click image for full size nodes
On 12/16/2018 at 6:19 PM, Carlosan said:
Normal map
Thanks for all the info! But unfortunately the problem remains. :/ It only flipped how the light was behaving, but you still can see the difference beetwen the uv islands. Like if each island had a different lighting position, dunno... so the seams appear like in the images above. Don't know what else to do... Thought this should be simple.
Are you using latest version 4.8.28A  ? Some baking problems was fixed on that version.
- Try exporting any default mesh (Shift+M) to check any issue with your project.
- Use applink to get direct connection in between apps.
It is not 28A. I will try updating! It is the steam version. And will try these other options as well. Thanks a lot!!
I will try to contact them, because I don't know how to update it from steam. It already has the option to update automatically, and since I purchased it a few weeks ago, I think maybe the steam version is outdated.
Yes, steam version is outdated.
- Hope this help:
source...
Blender expects normal maps in the OpenGL format. The difference between the two is that the green channel is inverted from one to the other, so in the end it doesn't matter what you use, if you know how to use it - you get the same result.
Only DirectX applications use DX normal maps. And DirectX run only under Windows mainly due to license. For everything else you need to use OpenGL. For sure is good always check documentation.
On image below you can find simple way how to convert DX to OpenGL (or OpenGL to DX)
enter image description here
- Hope this help:
On 12/18/2018 at 12:26 PM, InternetFriend said:
In blender make sure the image texture node going into the normal map is set to non-color data.
Hey! I updated to 4.8.28A and by setting non-color data on normal map it worked!! See this new model I am working on, it is working perfectly without those stupid seams!
Thanks a lot guys!!!
