ahmad
[Solved] Edge Loop doesn't work
Hi,
I am having an issue in the retopo room that stops me from finishing my projects, simply the Edge loop doesnt work at all, holding shift or Ctrl has no effect, even with seams, only ring loop is working, I have looked for it in the forums, installed few versions, reset, changed from DX to OGL .... nothing works, help please. thanks.
Hi
Testing 4.9.32 i found it working fine (Ctrl+LMB)
Do you like to test it ?
also .... this only happens with imported objects in the retopo room, all generated meshes inside 3dcoat are fine.
I am reporting this issue.
Thx
Thanks for pointing. Seems all edges of imported objects are marked as sharp. I will fix it in 4.9.33, but the workaround is to select all edges  with select tool and press "Clear Sharp".
4.9.33 is in official downloads. Generally, it really was working correctly in very old builds because sharp edges were not supported.
