Advanced Member Innovine Posted June 17, 2020 Advanced Member Report Share Posted June 17, 2020 (edited) Can we get a feature to allow export of ONE paint object? If I wish to make a texture atlas, I can import multiple objects, easily merge the UVs and textures to one UV set, but when it comes to exporting the models with the new UV data, they all get merged into one object in the .obj which is definitely not what I want. It would be great to export each separate paint object, either all in one operation (best) or one by one. Rigbht now, the solution is to save, delete all but one paint object, export, reload, delete all but the next object, export, reload.. and on and on Edited June 17, 2020 by Innovine 2 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2020 Report Share Posted July 22, 2020 This feature request was reported to support@3dcoat.com Quote Link to comment Share on other sites More sharing options...
Advanced Member Innovine Posted August 26, 2020 Author Advanced Member Report Share Posted August 26, 2020 On 7/22/2020 at 9:28 PM, Carlosan said: This feature request was reported to support@3dcoat.com Thanks. Do they have any comment on it? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted August 26, 2020 Reputable Contributor Report Share Posted August 26, 2020 Have you tried Export Separate Retopo Objects under the Retopo menu in the Retopo room. I would take that you have separate retopo objects as you have different models. Each Retopo Object will have the retopo object name in the exported model file. The uv set name stays the same so you retain the shared uv set. You deleted all the unused uv sets as well? Only left with one. I do not know how you imported your model for merging your UV sets. This chair is two separate retopo objects each having a uv set. Merged one to the other. Deleted the unused UV set. Exported as stated. I get two model files exported but each referencing the same uv set. The above is a method, I do not know if it will meet your workflow specific needs. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member pickers Posted October 22, 2020 Advanced Member Report Share Posted October 22, 2020 +1 for this feature. We should at least have the ability to export with is in view in the paint room. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 1, 2020 Report Share Posted December 1, 2020 Hi Send Andrew a feature request (andrewshpagin@gmail.com) reporting it. Thx Quote Link to comment Share on other sites More sharing options...
