New Member hawkman5879 Posted August 28, 2020 New Member Report Share Posted August 28, 2020 I am not sure what is happening here, I started this the other day, opened it up again today and now whenever i try to connect new faces to my retopology, it is a different color with a red line between them. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 28, 2020 Report Share Posted August 28, 2020 Hi Red lines means Seams created Use the command Clear Seams to delete it Quote Link to comment Share on other sites More sharing options...
New Member hawkman5879 Posted August 28, 2020 Author New Member Report Share Posted August 28, 2020 7 minutes ago, Carlosan said: Hi Red lines means Seams created Use the command Clear Seams to delete it It does not appear to be doing anything. Even if I delete an old face and recreate it, it is seemingly creating seams that i cant get rid of with clear seams. I just duplicated the layer and it isn't dong it on the duplicated layer. While this technically works I am still really confused why it was doing this to begin with. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 29, 2020 Report Share Posted August 29, 2020 Can you share with me (pm) the project to take a look ? Thx Quote Link to comment Share on other sites More sharing options...
Contributor Ctc_nick Posted September 4, 2022 Contributor Report Share Posted September 4, 2022 (edited) I have the same problem now in Coat2022.45 I cannot delete this seams, they appeared randomly. Is it okay to post in an old thread? I think it might be the same problem. Can only repair it with the new join clusters tool. Good thing. Greetings Edited September 4, 2022 by Ctc_nick Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 4, 2022 Report Share Posted September 4, 2022 The mesh only have one UVset ? Please share the model to take a look Quote Link to comment Share on other sites More sharing options...
Contributor Ctc_nick Posted September 5, 2022 Contributor Report Share Posted September 5, 2022 Hi! I have three UV sets unsorted right now. I did not pay much attention to the UVs because i'm just modelling right now. Sure, take a look. All the best! curve_car_wheel7.3b Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted September 5, 2022 Solution Report Share Posted September 5, 2022 Some faces of Polygroup26 & Polygroup10 are on UVset Polygroup2. Polygroup6 is on UVset Polygroup1 Are not unwraped, so are not visible on UV preview - Select all faces using this command or manually (I unwrapped it before) - Move to Default - Delete unused UVsets Use Joint Clusters to cleanup red lines curve_car_wheel7.3b 1 Quote Link to comment Share on other sites More sharing options...
Contributor Ctc_nick Posted September 5, 2022 Contributor Report Share Posted September 5, 2022 (edited) Thank you very much for your step by step guide. It works. So I'll pay more attention to UV Sets and their polygroup. Edited September 5, 2022 by Ctc_nick 1 Quote Link to comment Share on other sites More sharing options...
