3DCoat questions
Go to solution Solved by Евгений,
Carlosan
Yousung was awarded the badge 'Great Support' and 1 points.
1856418724_bandicam2022-01-1821-33-16-583copy.thumb.jpg.bb13ef2aceda53b42c4fca76e686ee8a.jpg
When you use Symmetry in Modeling Room, it appears to be working symmetrically in the viewport, but it is actually in a state before it was created.
It's because of Mesh - Virtual Mirror Mode, do Apply Symmetry or
You need to do Symmetry Copy from Polygroups.
  • 2 weeks later...
4 hours ago, Metin Seven said:
I just wanted to try the Radial Array, but I don't see anything change in my scene. Does it work in Voxel mode?
This question doesn't really matter anymore, as I've just discovered the Axial tool. Perhaps that's the successor to the Radial Array layer menu item?
Edited by Metin Seven
And another question... :)
What's the easiest way to create a straightforward (non-radial) array / ordered number of copies of a layer?
And is it possible to get the result into the same layer in stead of getting tens of layer copies?
Thanks in advance!
At around 16:50 in this video the creator activates Fill With Mesh Layer for a curve, then clicks on an item in the Splines panel to have the item follow the curve.
But when I try that, the old Curves tool gets activated and clicking on a Spline panel item doesn't make it follow the new curve type.
Can anyone help me out? Thanks!
https://youtu.be/scWV6jtxeXY?t=1009
  • Solution
Carlosan
Евгений was awarded the badge 'Helpful' and 1 points.
2 hours ago, Metin Seven said:
Примерно в 16:50 в этом видео создатель активирует заливку сетчатым слоем для кривой, затем нажимает на элемент на панели "Сплайны", чтобы элемент следовал за кривой.
Но когда я пытаюсь это сделать, активируется старый инструмент "Кривые", и нажатие на элемент панели "Сплайн" не заставляет его следовать новому типу кривой.
Кто-нибудь может мне помочь? Спасибо!
Он использовал данный инструмент и он работает . А так же вы можете менять масштаб используя радиус кисти , сняв галочку блокировки .
