Advanced Member Elemeno Posted August 17, 2022 Advanced Member Report Share Posted August 17, 2022 is it possible to replicate the zbrush roll brush in 3dcoat ? i can get dots and stamps but any curves in the strokes and the alpha jumps off position and doesnt blend if not, would be amazing for next year? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 25, 2022 Report Share Posted August 25, 2022 Hi The Strips panel offers an alternate selection of Brush tips, which repeat over the length of a stroke. Strips work best in the Paint Room for creating detail with normal map depth, in concert with per-pixel painting modes or, for actual displacement painting while using the micro-vertex method. For similar functionality in the Voxel Room, use the “Curves” tool with a repeating Spline shape selected from the “Splines” panel. The Strips panel uses the same methods of adding folders and individual strips as the Brushes panel. With the help of “Strip” menu you can select a shape of strip to be applied along the drawing trajectory. This may be used to draw decorative edging or a chain. Please contact Andrew Shpagin <andrewshpagin@gmail.com>, asking for other features. Thanks ! Quote Link to comment Share on other sites More sharing options...
