The Strips Panel
The Strips panel offers an alternate selection of Brush tips, which repeat over the length of a stroke.
Choosing a Strip shape overrides the alpha shapes in the Brushes panel. Strips work best in the Paint Room for creating detail with normal map depth, in concert with per-pixel painting modes, or, for actual displacement painting while using the micro-vertex method.
The 'X' means no strip will be applied along the trajectory.
For similar functionality in the Voxel Room, use the “Curves” tool with a repeating Spline shape selected from
the “Splines” panel. The Strips panel uses the same methods of adding folders and individual strips as the
Brushes panel.
With the help of “Strip” menu you can select a shape of strip to be applied along the drawing trajectory. This may be used to draw decorative edging or a chain.
Just as with Brushes, you can click on the “Folder” icon to add a new strip. There are a number of ways that you can apply a strip:
You can simply brush them in with your pen manually, or, you can create a spline curve and apply the strip to it.
Of course using a spline is very nice for getting an accurate strip, so it is recommended you try it with a curve first.
If it doesn’t suit your needs, or you require something more “loose” then you should try to manually brush it. It also helps to use the “Steady Stroke” feature when manually brushing a strip.
The image is a sample of how smooth and accurate using a spline curve to draw a strip can be.
Here you can see a very exemplary image, with the proper use of using a strip along a spline curve. The bandoleer around the persons shoulders was painted with the strip.
In this illustration, the bandolier was created with a standard Strip shape, totally within the Paint Room using the micro-vertex method of painting.
Tutorial
Strips: by Javis Jones.
