Member giobianco63 Posted April 12, 2023 Member Report Share Posted April 12, 2023 (edited) Hi, the curves tool has a bug when the "use spacing" check is activated and the "symmetry" is used the tool cannot draw the symmetrical curve completely. I attach screen. When, on the other hand, the "use spacing" check is removed, the bug does not appear, and the line is correctly executed also in the mirrored part. Obviously I need the check "Ignore back Faces" active version 3dcoattextura 2023.13 Giovanni Edited April 12, 2023 by giobianco63 1 1 Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted April 18, 2023 Solution Report Share Posted April 18, 2023 Looks like in 2023.16 it works correctly Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 23, 2023 Author Member Report Share Posted April 23, 2023 Hi, alsow in version 2023.16 the bug is present Giovanni 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 30, 2023 Report Share Posted April 30, 2023 Try version 2023.18 Quote Link to comment Share on other sites More sharing options...
