Noisemaker - thing a like?
Elowan
Go to solution Solved by Carlosan,
Please check this
- Sculpt room, work on surface mode
- Fill with freeze and/or stencil at paint room
- back to sculpt, now the surface model have freeze activated
- use any tool - in this example extrude tool
- fill through a mask:
1 - select freeze tool -> paint using any stencil and then
2 - select fill tool -> feel with freeze
post-10142-0-70052700-1421932175_thumb.j
  • Like 2
  • 3 weeks later...
The FILL tool in 3D Coat is the closest thing to ZBrush's Noisemaker, and it's pretty powerful, whether you use it for sculpting on a dense mesh, or wait til you have everything baked down to your low-poly mesh in the Paint workspace (Image-based sculpting, on your normal/displacement map). You may to watch all the videos covering it in the "Paint Tools" Playlist (3D Coat Youtube Channel)
