Member Elowan Posted January 22, 2015 Member Report Share Posted January 22, 2015 hello, in Zbrush, there is a tool for apply "noise pattern" to an object - do we have something similar in 3DC? See at 3:30 https://www.youtube.com/watch?v=47Ukn4zUSLA&index=2&list=PLUQP26mNfgEc70PDJSyRy1EWAQ5FssVZ2 regards Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted January 22, 2015 Contributor Report Share Posted January 22, 2015 There is a Noise Generator in Surface Mode, but it have not the power of the generator like in Zbrush. Quote Link to comment Share on other sites More sharing options...
Member Elowan Posted January 22, 2015 Author Member Report Share Posted January 22, 2015 Ahhhh, surface mode, ok! Will give it a shot, then... Danke! Quote Link to comment Share on other sites More sharing options...
Member Elowan Posted January 22, 2015 Author Member Report Share Posted January 22, 2015 ...oh and how can I generate a mask from the surface of the object, for the noise generator? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 22, 2015 Report Share Posted January 22, 2015 Please check this - Sculpt room, work on surface mode - Fill with freeze and/or stencil at paint room - back to sculpt, now the surface model have freeze activated - use any tool - in this example extrude tool - fill through a mask: 1 - select freeze tool -> paint using any stencil and then 2 - select fill tool -> feel with freeze 2 Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted January 22, 2015 Contributor Report Share Posted January 22, 2015 As far as i know, there is no automasking. You have to do it by painting. Quote Link to comment Share on other sites More sharing options...
Member Elowan Posted January 22, 2015 Author Member Report Share Posted January 22, 2015 ah ok ! thank you both Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted January 22, 2015 Solution Report Share Posted January 22, 2015 - Sculpt room, work on surface mode - Fill with freeze at paint room - use Noise tool at Sculpt room - back to Paint Room 2 Quote Link to comment Share on other sites More sharing options...
Member Elowan Posted January 22, 2015 Author Member Report Share Posted January 22, 2015 would be great if a user-made-mask cold be provided to "Fill with Freeze" function... Anyways, will test it Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 22, 2015 Report Share Posted January 22, 2015 This option is inside Fill Room - Add Custom (Cube projection / or UVmap if is needed) 1 Quote Link to comment Share on other sites More sharing options...
Member Elowan Posted January 22, 2015 Author Member Report Share Posted January 22, 2015 Wooohuuuuuuuuuuu that´s cool!!!! Can not wait to test it Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 22, 2015 Report Share Posted January 22, 2015 glad to help will be nice to see your test and to share workflows Quote Link to comment Share on other sites More sharing options...
Member Elowan Posted January 23, 2015 Author Member Report Share Posted January 23, 2015 I came across some other issues... not tested the "Nosiemaker-workflow" right now Will test asap and report back... Cheers Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 9, 2015 Reputable Contributor Report Share Posted February 9, 2015 The FILL tool in 3D Coat is the closest thing to ZBrush's Noisemaker, and it's pretty powerful, whether you use it for sculpting on a dense mesh, or wait til you have everything baked down to your low-poly mesh in the Paint workspace (Image-based sculpting, on your normal/displacement map). You may to watch all the videos covering it in the "Paint Tools" Playlist (3D Coat Youtube Channel) 1 Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted February 9, 2015 Contributor Report Share Posted February 9, 2015 Wow! Great ideas here. A lot of new ways to work that hadn't occurred to me! Quote Link to comment Share on other sites More sharing options...
