Advanced Member arumiat Posted January 23, 2015 Advanced Member Report Share Posted January 23, 2015 So I'd like to update to the latest stable 3DC version from 4.1.04A. I can't find instructions for this. Is there a recommended approach? Eg 1. Save options.xml 2. uninstall current 3DC 3. install new 3DC 4. add options .xml back? Thanks in advance, T Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 24, 2015 Report Share Posted January 24, 2015 do backup of folder MyDocs/3D-CoatV4 For example, rename it MyDocs/3D-CoatV4 to MyDocs/3D-CoatV4_OLD, run beta, work there. If you want to get back to 4.1.17D - rename or copy MyDocs/3D-CoatV4_OLD to MyDocs/3D-CoatV4 If you want to copy, migration master could help Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution digman Posted January 24, 2015 Reputable Contributor Solution Report Share Posted January 24, 2015 (edited) I think Carlosan that arumiat wants to upgrade just to 4.1.17D (last stable version posted at the 3DC official website). from his current version 4.1.04A. Generally you can just install over the current version you have. Of course you can uninstall the current 3DC plus remove it's folder under Documents and Settings, then install to get a complete clean copy plus you will have to re-register your copy of 3DC. Any settings/alphas/materials / hotkeys etc from your old version you have will be lost. I have not used migration master yet so can not tell you how it functions in detail. Edited January 24, 2015 by digman Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted January 24, 2015 Author Advanced Member Report Share Posted January 24, 2015 (edited) Thanks. I ended up amending the old folder to 3DCoat_V4_OLD, then uninstalled and clean a installed version of 4.1.17D. Edited January 24, 2015 by arumiat Quote Link to comment Share on other sites More sharing options...
Member ConsciousActs Posted February 20, 2015 Member Report Share Posted February 20, 2015 Ok, so here's an interesting problem... I want to do a clean install to go to v4.5 beta 12, and make sure none of my older stuff interferes. However when I open Windows7 add/remove programs, I get nada in the list. I know I have 4.1 and 4.5 beta 11 installed, and I had renamed my the 'my documents' directory for 4.1.x to "3D-CoatV4_Backup" prior to installing 4.5. I'd like to try totally cleaning out *all* of the different places that may have stuff installed to them, to *really* start fresh. Is this listed anywhere that I'm missing? Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted February 21, 2015 Contributor Report Share Posted February 21, 2015 You find the uninstall file in your install folder. Quote Link to comment Share on other sites More sharing options...
