Member LudvikKoutny Posted December 22, 2017 Member Report Share Posted December 22, 2017 Hi, I am having a hard time figuring out how to use transform gizmo to scale an object in just two axes. It's an extremely frequent operation I need almost all the time. For example I want to scale only width of a cylinder without scaling its height. Right now I am working around it by scaling the entire object uniformly, and then scaling it down on one axis, but that's very bad, because then I have to realign object back on its correct place. I must be missing something, because every software has this option. How do I do it in 3DCoat? Thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 23, 2017 Report Share Posted December 23, 2017 Hi Select the little yellow cubes in axis extremes to scale an object in just two axes . Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 23, 2017 Reputable Contributor Report Share Posted December 23, 2017 3 hours ago, Carlosan said: Hi Select the little yellow cubes in axis extremes to scale an object in just two axes . I think he means making a transform where it scales or moves along 2 axis simultaneously....such as scale the width along the X axis and up in the y axis at the same time. You can do this in most 3D apps...just not 3D Coat. The closest thing is to grab the small circle in the middle, to move the object in screen space (2 axis), but it's not quite the same. I've asked Andrew for this multiple times, to no avail. Quote Link to comment Share on other sites More sharing options...
Member LudvikKoutny Posted December 23, 2017 Author Member Report Share Posted December 23, 2017 Yep, exactly... It's quite perplexing that such essential functionality is missing from such a complex piece of software with such a long history... :| Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted December 31, 2017 Report Share Posted December 31, 2017 Ok, introduced 2 axis transform, wait for next build... 4 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 11, 2018 Report Share Posted January 11, 2018 4.8.09 - Updated transform gizmo - non uniform scaling in plane introduced. Quote Link to comment Share on other sites More sharing options...
