Advanced Member arumiat Posted November 17, 2018 Advanced Member Report Share Posted November 17, 2018 In a recent print I tried out the 3DC joint creation tool to see if I was able to use it to connect pieces of my print together. I've attached some pics of the kind of joints I tried as this was the first time. The prints were done in nylon12 on an industrial printer by a bureau. Unfortunately none of the joints have any friction in them, if trying to attach the pieces they just fall off. I wonder if the print quality is too fine, - the joint tool is made for a lower print resolution (which will increase friction perhaps?) Would be great to get some tips if anyone has used the joint tool successfully. Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted November 22, 2018 Report Share Posted November 22, 2018 Hello! Try turning this option off. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 5, 2018 Author Advanced Member Report Share Posted December 5, 2018 Thank you Oleg! I will try Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 13, 2018 Author Advanced Member Report Share Posted December 13, 2018 (edited) A question @Oleg_Shapo, so I don't need to redo the joints, just export the exact same model with that setting off? Edited December 13, 2018 by arumiat Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 13, 2018 Author Advanced Member Report Share Posted December 13, 2018 Also @Oleg_Shapo, when I try export with the 'Export for 3D printing' item in the file menu, rather than the normal export item/menu, nothing seems to get exported. I get an almost empty file. Any advice? Recording #621.mp4 Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted December 14, 2018 Report Share Posted December 14, 2018 The process of saving the stl file takes some time. Please send a 3b file to the mail resell@3dcoat.com Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 14, 2018 Author Advanced Member Report Share Posted December 14, 2018 I left for over 5 minutes and nothing,nothing seems to be happening in 3DC either. Sending now @Oleg_Shapo Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 17, 2018 Author Advanced Member Report Share Posted December 17, 2018 I saw you download @Oleg_Shapo, any luck seeing the issue? Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted December 18, 2018 Report Share Posted December 18, 2018 Your object is too small. Try to scale it and everything will turn out. Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 18, 2018 Author Advanced Member Report Share Posted December 18, 2018 (edited) The scale is preventing the export @Oleg_Shapo ? It's a slight issue as this is the correct real-world size that it needs to be printed at Edited December 18, 2018 by arumiat Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 18, 2018 Report Share Posted December 18, 2018 Hello I have a similar issue. Export stl take very long time using all comp resources freezing the app. Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted December 18, 2018 Report Share Posted December 18, 2018 6 hours ago, arumiat said: The scale is preventing the export @Oleg_Shapo ? It's a slight issue as this is the correct real-world size that it needs to be printed at It's true, do you need parts of this size? Quote Link to comment Share on other sites More sharing options...
Advanced Member arumiat Posted December 20, 2018 Author Advanced Member Report Share Posted December 20, 2018 Hi @Oleg_Shapo, I scaled up so that the pieces are approximately 2cm according to 3DC scale. If I export as an stl using normal export it comes out fine: When I use the export for 3D printing menu it comes out like this: Are you sure the tool works as expected? Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted December 21, 2018 Report Share Posted December 21, 2018 I sent the file to Support@3dcoat.com. We solve this problem. Quote Link to comment Share on other sites More sharing options...
Member xrok1 Posted March 10, 2019 Member Report Share Posted March 10, 2019 On 11/17/2018 at 2:24 AM, arumiat said: In a recent print I tried out the 3DC joint creation tool Where is this tool? Is it in 3DCP as well? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 10, 2019 Report Share Posted March 10, 2019 Switch to Surface mode to gain access to Joint tool Quote Link to comment Share on other sites More sharing options...
Member xrok1 Posted March 10, 2019 Member Report Share Posted March 10, 2019 Interesting. Thank you. Is there a surface offset to allow for print tolerance? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 11, 2019 Report Share Posted March 11, 2019 You can RMB over the mesh layer and select the command extrude Hope it help Quote Link to comment Share on other sites More sharing options...
New Member Johnthewarlock Posted March 5, 2020 New Member Report Share Posted March 5, 2020 On 12/20/2018 at 6:54 AM, arumiat said: Hi @Oleg_Shapo, I scaled up so that the pieces are approximately 2cm according to 3DC scale. If I export as an stl using normal export it comes out fine: When I use the export for 3D printing menu it comes out like this: Are you sure the tool works as expected? I am getting the same results as @arumiat when I export some models for 3d printing. They look great and have a lot of resolution in the sculpting window, but when opening them they look like melted wax. In Dec 2018 it was noted that it was sent to support, but I do not see where it was fixed or extra steps to take. Can someone help me to correct this? Quote Link to comment Share on other sites More sharing options...
Oleg_Shapo Posted March 6, 2020 Report Share Posted March 6, 2020 Please write, what layer thickness do you set in the export menu for 3D printing? Quote Link to comment Share on other sites More sharing options...
Member Archester Posted April 10, 2020 Member Report Share Posted April 10, 2020 Hi there, same problem here. When exporting for 3D printing the solids turn in low-poly objects. How can I solve this problem? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 10, 2020 Report Share Posted April 10, 2020 Hi Issue was solved on latest version 4.9.38 Quote Link to comment Share on other sites More sharing options...
