There is one way.
Attach a Smart material to a layer. It will show a small icon in the layer of the Smart material. Now if you select another layer and then re-select the layer with the attached Smart Material it will be highlighted in the Shaders Panel. You can only attach one Shader per layer.
Hover your mouse over the icon in the layer and a larger preview will appear. There is no name given but the preview is fairly large.
Once a Smart Material has been attached to the layer
Posted by digman,
2 reactions
Go to this post
