Member Hao Posted February 22 Member Report Share Posted February 22 (edited) I have to manually rotate 90 degree everytime importing assets from blender if the Zup coordinate system is enabled. But blender is a Z up coordinate system, should be a simple fix but making my life a lot easier. Thank you~ Edited February 22 by Hao Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted February 22 Report Share Posted February 22 41 minutes ago, Hao said: But blender is a Z up coordinate system Try changing this in Preferences. Quote Link to comment Share on other sites More sharing options...
Member Hao Posted February 23 Author Member Report Share Posted February 23 (edited) 20 hours ago, Oleg_Shapo said: Try changing this in Preferences. That is exactly my piont, I have to manually rotate 90 degrees If I enable Z-up coordinate system What I'm trying to suggest was to automate this, see screenshot attached. This is what fresh import looks like Edited February 23 by Hao Screenshot added Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 24 Report Share Posted February 24 Working with Blender, I usually have Z-up turned off and it is work fine. Why do you need to activate Z-up coordinate system ? Quote Link to comment Share on other sites More sharing options...
Member Hao Posted February 25 Author Member Report Share Posted February 25 18 hours ago, Carlosan said: Working with Blender, I usually have Z-up turned off and it is work fine. Why do you need to activate Z-up coordinate system ? Emmm, because I swtich between them constantly and the hotkey are different. Consistant hotkey works better for me. Quote Link to comment Share on other sites More sharing options...
Member Hao Posted February 25 Author Member Report Share Posted February 25 (edited) Now it has a new problem, I can seem to turn off Z-up coordinate system. Everytime I send something from blender, it would automatically turn on. Video attached. 2024-02-25 10-50-37.mkv Edited February 25 by Hao Video added Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 25 Report Share Posted February 25 Bug reported thanks for point it up Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 25 Report Share Posted February 25 May someone reproduce it? On my side it is Y up always when interacts with Blender. What version do you use? Quote Link to comment Share on other sites More sharing options...
Member Hao Posted February 26 Author Member Report Share Posted February 26 7 hours ago, Andrew Shpagin said: May someone reproduce it? On my side it is Y up always when interacts with Blender. What version do you use? I am using blender 4.0 and 3dcoat 2024.07 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 26 Report Share Posted February 26 Both are at beta stage. Try using stable versions. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 26 Report Share Posted February 26 24 minutes ago, Carlosan said: Both are at beta stage. Try using stable versions. This may not be reason. Try to remove the folder Documents/Applinks Quote Link to comment Share on other sites More sharing options...
Member Hao Posted February 26 Author Member Report Share Posted February 26 11 minutes ago, Andrew Shpagin said: This may not be reason. Try to remove the folder Documents/Applinks I tried deleting the folder, it still automatically checking the Z-up for me. Quote Link to comment Share on other sites More sharing options...
Member Hao Posted February 28 Author Member Report Share Posted February 28 On 2/26/2024 at 3:58 PM, Andrew Shpagin said: This may not be reason. Try to remove the folder Documents/Applinks After you said you couldn't reproduce the bug, I fresh installed version 2024.13(stable) On fresh new re-install of 3D coat, it does not automatically enable the Z-up but disable it for me. Which means if I was using Z up in the 3d coat setting, sending something from blender (which is z-up as well) will automatically change 3dcoat work space to Y-up, it still does not make any sense to me. It should stick to the user preference and autotranslate the desired workspace between apps, right? And this bug has driven me insane... Please help Quote Link to comment Share on other sites More sharing options...
Member Lokich Posted February 28 Member Report Share Posted February 28 Tried to repeat the described problem (both programs Z up). First, when exporting from blender to coat, the model inported oriented by Y up. I deleted the Documents/Applinks folder and now I ha ve the same error, automatic switching from Z up to Y up after import. 2024-02-27 22-25-22.mkv 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 28 Report Share Posted March 28 Try on 3DC do not use Z up importing/exporting when work with Blender. Quote Link to comment Share on other sites More sharing options...
