Member jimiclay Posted November 8, 2010 Member Report Share Posted November 8, 2010 I'm running on XP Pro 64, with an Nvid 8800GT Card, 8 Gigs of Ram and Dual 2 Quad Intel Core2 Q8200 processors @ 2.33GHz. My question is, which version of 3D Coat should I install for best performance? When I first installed the 3.5 update, the options were open GL and Direct X, (which is supposed to be faster). I'm pretty sure my computer is too old for the CUDA version, but I'm just asking anyway. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted November 8, 2010 Contributor Report Share Posted November 8, 2010 I'm running on XP Pro 64, with an Nvid 8800GT Card, 8 Gigs of Ram and Dual 2 Quad Intel Core2 Q8200 processors @ 2.33GHz. My question is, which version of 3D Coat should I install for best performance? When I first installed the 3.5 update, the options were open GL and Direct X, (which is supposed to be faster). I'm pretty sure my computer is too old for the CUDA version, but I'm just asking anyway. We have same cpu. I have very old system too. Your card support Cuda.Just install latest drivers if you havent already. And Xp64 is better os than Vista/Win7 IMO. So install 3DC Cuda64 builds and run DX version it should be a little faster but try GL too,you will maybe have a surprise. Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 Thanks, Will do! I'm a bit surprised to hear that Windows 7 isn't really better than XP 64. May I ask why you say this? Would really like to know before I run out and buy Windows 7. thanks Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 ok, So I got a warning message that says, "(Cuda drivers)has not passed Windows Logo testing to verify its compatibility with this version of Windows. Continuing to install this software may impair or destabilize the correct operation of your system, yada yada yada, we strongly recommend that you stop this install now, and so forth. Whats up with this? Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted November 8, 2010 Contributor Report Share Posted November 8, 2010 Thanks, Will do! I'm a bit surprised to hear that Windows 7 isn't really better than XP 64. May I ask why you say this? Would really like to know before I run out and buy Windows 7. thanks WinXp 64 is the best windows os IMO. http://www.testfreaks.com/blog/information/windows-xp-vs-vista-vs-7/ Its faster and and less problematic in my experience. I have vista now and cant revert for many reasons,but when I had Xp 3DCoat felt very strong on it. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted November 8, 2010 Contributor Report Share Posted November 8, 2010 ok, So I got a warning message that says, "(Cuda drivers)has not passed Windows Logo testing to verify its compatibility with this version of Windows. Continuing to install this software may impair or destabilize the correct operation of your system, yada yada yada, we strongly recommend that you stop this install now, and so forth. Whats up with this? Try this one. (but keep old one as backup,of course) http://www.nvidia.com/object/winxp64-258.96-whql-driver.html Quote Link to comment Share on other sites More sharing options...
Member ace63 Posted November 8, 2010 Member Report Share Posted November 8, 2010 Windows 7 is fine, you won't have problems with it when you use 3D Coat or do 3D in general, but xp64 is indeed faster. I had to do the switch because of Adobe CS5 which refuses to install on xp Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 OK, Well I still have a question. There's the CUDA install, and then there's the dx9c install. Which one do I need to install? Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 Windows 7 is fine, you won't have problems with it when you use 3D Coat or do 3D in general, but xp64 is indeed faster. I had to do the switch because of Adobe CS5 which refuses to install on xp Good to know. And I can appreciate your situation with XPPro. I couldn't use my install of Vegas when I moved to XP 64, so I got CS4 Suite instead. I preferred Vegas, but I'm not prepared to give up on XP yet. So here I sit. Quote Link to comment Share on other sites More sharing options...
Javis Posted November 8, 2010 Report Share Posted November 8, 2010 OK, Well I still have a question. There's the CUDA install, and then there's the dx9c install. Which one do I need to install? Hi! You'll need to install both CUDA and DX9c for it to work. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted November 8, 2010 Report Share Posted November 8, 2010 OK, Well I still have a question. There's the CUDA install, and then there's the dx9c install. Which one do I need to install? Both dx 9c is required regardless of the version you run. (Possibly aside from the Open GL version) Quote Link to comment Share on other sites More sharing options...
Javis Posted November 8, 2010 Report Share Posted November 8, 2010 Windows 7 is fine, you won't have problems with it when you use 3D Coat or do 3D in general, but xp64 is indeed faster. I had to do the switch because of Adobe CS5 which refuses to install on xp Good to know. And I can appreciate your situation with XPPro. I couldn't use my install of Vegas when I moved to XP 64, so I got CS4 Suite instead. I preferred Vegas, but I'm not prepared to give up on XP yet. So here I sit. A wise decision! XP is still the strongest, best and fastest Win OS there is. Win7 is alright, but still has it's issues. I hope their next Win OS is rock solid like XP was, or better (which it really better be!). Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 Tnanks guys. I'll install it now Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 OK, so now they're asking me where do I want to install the files from the dx9c install. First off, I don't know what these files are, and 2nd, I don't have a clue as to where they should be installed. I'm looking n the manual now, but I don't see anything on this yet. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted November 8, 2010 Report Share Posted November 8, 2010 Is that the Microsoft installer? It shouldn't matter where you install it. Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 Is that the Microsoft installer? It shouldn't matter where you install it. Yeah, that's the one. I chose to install it in the 3d coat folder under programs (x86). I hope that's ok Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted November 8, 2010 Report Share Posted November 8, 2010 I'm not sure, I think I just ran an upgrader to update the one that came with Windows. Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted November 8, 2010 Author Member Report Share Posted November 8, 2010 Well I certainly won't hold that against ya dude. I need your help on another topic, which I posted under the new users category. My uv map won't export from my model. help pleeeez? Quote Link to comment Share on other sites More sharing options...
