Andrew Shpagin Posted February 4, 2008 Report Share Posted February 4, 2008 I have released 2.05. It is really big piece of work. So, the list of changes: General changes: 1) Adaptive geometry: now geometry will be additionaly automatically subdivided during edit process in dependence of details to get well displaced surface. It is very new and algoritmically very complex feature. 2) You can import big meshes now, up to 700 K. Many optimisatons was done to make it possible. 3) You can alter level of initial subdivision during mesh import. Now you can specify mid-poly mesh resolution. 4) new measure tool, you can measure distance in most common units - meters, inches, yards, miles, etc. Also the coordinate of picked point is printed in the right bottom corner. 5) New method of custom material mapping in custom fill pattern - mapping over existing uv-set. It allows to paing clothes in more easy way. 6) Masks are implemented. The mask is modulator for pen depth and transparency. The mask and materials could be moved and rotated independently using new navigation controls. 7) Masks and materials could be rotated discretely on 45 degrees using SHIFT. Many stability improvements. 9) New interface style. Interface looks now more clear and sharp. 10) jpg export is correct now. Curves changes: 11) Some curve points could be marked as sharp. So you can make square forms in easy way. 12) Whole curve could be moved/scaled/rotated using new navigation controls. 13) Curve can be closed. 13) You can draw arrows in easy way. 14) New curve drawing mode - spacing mode. Points will be set along curve with some spacing and jittering. It allows to make new effects with cirves. 15) Curves will be drawn correctly, even if knot points are far from each other and surface between them is curved much. Layers changes: 16) Layers masking (linking) is implemented. One layer can mask another layer in non-destructive way. 17) You can freeze the transparent or painted area of the layer. In this way you can use layer's transparency to paint selectively on another layers. It is like CTRL+click on layer in Photoshop. You can use CTRL+click on layer in 3DB now. Welcome to downloads section http://www.3d-brush.com/trial.html Quote Link to comment Share on other sites More sharing options...
Advanced Member paulrus Posted February 4, 2008 Advanced Member Report Share Posted February 4, 2008 Your web server seems to be having some problems. I'm getting all sorts of mySQL errors when I try to log in and download the latest version. Paul Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 4, 2008 Author Report Share Posted February 4, 2008 Your web server seems to be having some problems. I'm getting all sorts of mySQL errors when I try to log in and download the latest version.Paul now works Quote Link to comment Share on other sites More sharing options...
Member Chuckpie Posted February 4, 2008 Member Report Share Posted February 4, 2008 Andrew; You are doing such a good job that I hate to nag. I did not give a very good explanation of what I would have liked when I ask for English (US) measurement standards. What I really wanted was like Lightwave's options, where I could select the type of measurement standards I wish to use as the program's default standards, either English (US) Feet, inches, etc. or Metric. That would allow anything I build in 3D Brush to match my exported work to Lightwave. No real big deal, just a matter of convenience. Thanks Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 4, 2008 Contributor Report Share Posted February 4, 2008 [Andrew The download site says it has no memory of my e-mail address! (Therefore I can not sign in to download?) Quote Link to comment Share on other sites More sharing options...
Advanced Member jaf Posted February 4, 2008 Advanced Member Report Share Posted February 4, 2008 Yes, I can't login either and when I submit my email address for "Forgot my password", it says it cannot find my account. Quote Link to comment Share on other sites More sharing options...
Guest Lottmedia Posted February 4, 2008 Report Share Posted February 4, 2008 I was having problems like this too, but andrew fixed me up. Th purchasing and downloading sites are different, just regester with the downloading site and you're fine Casey Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 5, 2008 Contributor Report Share Posted February 5, 2008 I was having problems like this too, but andrew fixed me up. Th purchasing and downloading sites are different, just regester with the downloading site and you're fine Casey NO---That does not work . Quote Link to comment Share on other sites More sharing options...
Member xrok1 Posted February 5, 2008 Member Report Share Posted February 5, 2008 try this http://3d-brush.com/files/3d-brush-2-05-en.exe Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 5, 2008 Contributor Report Share Posted February 5, 2008 try this <a href="http://3d-brush.com/files/3d-brush-2-05-en.exe" target="_blank">http://3d-brush.com/files/3d-brush-2-05-en.exe</a> xrog1. Did you get the ok to provide that that? It is NOT right! Quote Link to comment Share on other sites More sharing options...
Member xrok1 Posted February 5, 2008 Member Report Share Posted February 5, 2008 what do you mean the ok? just had to look for it based on the past files. its still the demo version, not a pirate. all the other files were provided from there. P.S you're welcome. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 5, 2008 Contributor Report Share Posted February 5, 2008 what do you mean the ok? just had to look for it based on the past files.its still the demo version, not a pirate. all the other files were provided from there. P.S you're welcome. You were directing us to the Beta (which most of us would have had) not the final .5 version which is now listed! Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted February 5, 2008 Advanced Member Report Share Posted February 5, 2008 Im downloading it from the demo page. No problem logging in for me. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 5, 2008 Contributor Report Share Posted February 5, 2008 Im downloading it from the demo page. No problem logging in for me. Still as attaced for me still! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 5, 2008 Author Report Share Posted February 5, 2008 Still as attaced for me still! Excuse for some inconvenience! You should press "Register now" and register and then you will be able to download. The purchasing and registering are different things. But I see that you have tired because of this procedure. Really there is some misunderstood because if you have purchased 3DB you suppose that you have already registered. But registration requires a password, but purchasing - no. So registration and purchasing are different. So may be it is better to give you a direct link: http://3d-brush.com/files/3d-brush-2-05-en.exe xrok1 has given really correct link. Quote Link to comment Share on other sites More sharing options...
webmaster Posted February 5, 2008 Report Share Posted February 5, 2008 Yes, I can't login either and when I submit my email address for "Forgot my password", it says it cannot find my account. I have found your registration. You used the same email as in forum registration. I checked and it work properly. Please try it again and tell me about result. Quote Link to comment Share on other sites More sharing options...
webmaster Posted February 5, 2008 Report Share Posted February 5, 2008 Still as attaced for me still! As Andrew say it is new registration just to download the program. So if you have already register on forum or purchased 3db you have to register on Registration page: http://www.3d-brush.com/register_form.php If you have already register there, please write me some info from your registration so I can find and check it. Please tell me what did you write in field Your firstname* or Your lastname*. Sorry for inconvenience. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 5, 2008 Contributor Report Share Posted February 5, 2008 As Andrew say it is new registration just to download the program. So if you have already register on forum or purchased 3db you have to register on Registration page: http://www.3d-brush.com/register_form.phpIf you have already register there, please write me some info from your registration so I can find and check it. Please tell me what did you write in field Your firstname* or Your lastname*. Sorry for inconvenience. I still really dont know what you are meaning. It all is a very odd way of doing thingas. That (administrator) download you last gave did install as 2.05 The download that xrog1 gave loaded as 2.05Beta3 I presume I do not have to take any other action---go through any further registration proceedures or whatever.. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 5, 2008 Author Report Share Posted February 5, 2008 I still really dont know what you are meaning. It all is a very odd way of doing thingas.That (administrator) download you last gave did install as 2.05 The download that xrog1 gave loaded as 2.05Beta3 I presume I do not have to take any other action---go through any further registration proceedures or whatever.. So, now all is done and well? Have you downloaded and installed it? Quote Link to comment Share on other sites More sharing options...
Advanced Member yukon_28 Posted February 5, 2008 Advanced Member Report Share Posted February 5, 2008 Thanks Andrew, what a great update. I like new curves, also freeze layers on CTRL+click like in photoshop is very good feature. I believe Photoshop-like tools\features\shortcuts is a great way to get your software better, many (if not all) of us know photoshop and is pure joy to be able to use photoshop-like tools in such a great way in 3D. Also, IMHO your additions and improvements to spline\curve tools is a good things to add now, because is very unique tools for 3db, making them better will make whole program more special and unique. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 5, 2008 Author Report Share Posted February 5, 2008 Thanks Andrew, what a great update. I like new curves, also freeze layers on CTRL+click like in photoshop is very good feature. I believe Photoshop-like tools\features\shortcuts is a great way to get your software better, many (if not all) of us know photoshop and is pure joy to be able to use photoshop-like tools in such a great way in 3D. Also, IMHO your additions and improvements to spline\curve tools is a good things to add now, because is very unique tools for 3db, making them better will make whole program more special and unique. Yeah, Photoshop has a good set of commands... I hope non-destructive curves layers, text layers and layer effects are not so far from realisation. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member yukon_28 Posted February 7, 2008 Advanced Member Report Share Posted February 7, 2008 I hope non-destructive curves layers, text layers and layer effects are not so far from realisation. Wow, cant wait to see layer fx in action. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 7, 2008 Author Report Share Posted February 7, 2008 Wow, cant wait to see layer fx in action. One of fx-es you can use even now - bulging (in layer options). It is like emboss in Photoshop. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted February 8, 2008 Contributor Report Share Posted February 8, 2008 [Will the updated Help and Manual be available soon Andrew? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 8, 2008 Author Report Share Posted February 8, 2008 [Will the updated Help and Manual be available soon Andrew? We are trying to update manual as soon as possible. But the speed of development if more than manual updation. I will update the manual soon. 1 Quote Link to comment Share on other sites More sharing options...
