Posts
128 -
Joined
Last visited
Calendar
Gallery
Everything posted by Hammers
My gizmo seems to appear disappear fairly randomly and I can't figure out how to get it back when it's gone... any ideas? Also sometimes the preview option panel controls just don't do anything... Not sure if the mac version is less tested than the windows one, but I have so many little random intermittent problems I find it quite frustrating, and I don't usually have time to test and put together bug reports... Makes learning quite tricky
Thanks for the suggestions. I'm still going round in circles a bit, but gradually figuring out the relations between rooms. Javis' video doesn't really mention building/editing retopo meshes based on sculpts, but ah well. Learning stuff is good.
Further to this, I've now managed to bake the hair, and have unwrapped the head UVs in Retopo room and moved them to their own UV set. My understanding is this corresponds with the Surface Material. But I still can't figure out how to get the retopo mesh converted into a paint object, other that the already existing one for the hair. Going round in circles, please excuse all my questions EDIT: I found a way, only by baking both objects at once, which shouldn't be necessary, since it leaves less room for finessing bake settings. Does anyone know a way to successfully bake from Retopo->new Paint object when a different one already exists?
Working on a retopo->bake project. I autopo'd to get my medium poly mesh. I was working on the UV seams when I discovered a hole in the mesh. I went to the Retopo room, repaired the mesh, but the changes weren't propagated to the UV room. So I thought I would try doing the unwrapping in the retopo room, after I discovered I needed to click mark-seams to reveal the UV tools. After baking, I found that the bake was based on my partially made UV room UVs rather than the updated retopo room mesh. Anyone suggest how best to handle this and similar situations? Thanks!
A lot of my confusion in learning 3D coat is exacerbated because I haven't really cracked how the different data types work together in the program. For example, until today, I've assumed that retopo mesh is the same even if you switch to the UV room, but that doesn't seem to be the case. If I tweak the mesh in the Tweak room, it updates in the UV room, but not the retopo room (where I would normally rebake a texture for example.) This is just one of many confusions I've had lately. I think it would be great to have some really clear documentation or flowcharts showing how everything interrelates, for noobs like me. How do UV sets, tiles, retopo objects, paint objects, surface materials etc. link together. What bakes to what, and why? I know the manual explains the basics, but seeing a clearly structured overview would probably help me. Thanks!
bake [Solved] couldn't bake normal map
Hammers replied to biscuitguy's topic in SOS! If you need urgent help for 3DCoat
I'm having this issue baking to the paint room too. My shader in the sculpt room isn't even using normal/bumpiness. So I don't know what gives... Edit: Trying with Bake update to Paint Layers, seems to work better, Bake w/ Normal Map has same problem ie. noisy normals. -
Strip voxel sculpting stops working after changing strip alpha. Been messing with strips in voxel room today, using airbrush/build/extrude. I found that after changing the strip alpha around 3 times the tool would stop sculpting. If I change then, say airbrush to build then back again, the tool would function correctly again. Mac 10.12.6, v4.8.03 EDIT: Just tried in surface mode with General Clay LC mode. Same issue between one and three strip changes and tool stops working. Switch tool and back again, all good. Perhaps this is more widespread—I'll keep an eye out and report back if it happens in other circumstances. EDIT2: Tried paint room with brush tool and strips, same thing. Switch to pencil and back -> correct behaviour.
Blender Applink "Simple3DCoat" (Fork of the official) by mifth
Hammers replied to mifth's topic in 3DCoat AppLinks
I've just been thinking the same thing. At least the principled shader makes everything much easier to set up.- 153 replies
- export
- 3dcoatapplink
(and 3 more)
Tagged with:
I'm having trouble getting this to work. Using Edu version of 2016, plugin shows in plugin manager but gives me: -------------------------------- // Error: line 1: ApplinkError: file /Users/Stephen/Library/Preferences/Autodesk/maya/2016/plug-ins/3dc_applink.py line 57: Registration failed for <coatExport> command. // // Warning: line 1: Failed to call script initialize function // // Error: line 1: (3dc_applink) // I'm on OSX10.9.5 btw
Just wondering if anyone has this app kicking around anymore. It seems to not exist on iTunes now, and would love to give it a try. Please let me know if you have a copy EDIT: nm, found a download here. http://apple.vshare.com/421230117.html This may be another reason to keep the ol' iPad 1 alive.
12th Challenge: A scene from a classic fairy tale
Hammers replied to ajz3d's topic in Member Contests
Try 'The Nightingale and the Rose' for a taste of Oscar's fairy tales. It makes my insides ache... I'm not sure yet what I can fit in this week, so don't extend the deadline on my behalf. Thanks for replying, and good luck to all. -
As usual I find these challenges when they're just about over, or I have no spare time What is the latest on the deadline for this one? Got a few ideas and would still be nice to have a go. I'm also thinking about maybe an Oscar Wilde fairy tale... Classic enough? -
From the album: Hammers' hand hewn handiworks
A slightly moodier monkey, just to try out some PBR materials. -
Just a follow up note on that, the autosmooth left at 180º just picked up the sharp edges, and seemed more discriminating than the edge split mod. This actually helped me find a couple of bad internal faces that were causing shading problems. I tried exporting fbx without the modifier, and the edges came through without a hitch. I set the export to smooth 'normals only', not sure if that matters or not. Anyway, I think I'll be using autosmooth a lot more from now on
Thanks for the ideas guys! The obj from B to 3dc was ok if I applied the edge split modifier, but that messed up the topology and I couldn't delete those edges in the UVs. But with .fbx from Blender I inadvertently left "apply modifiers" on, yet it still worked! So I think your last suggestion seems the most sensible Carlosan. @Daniel. I'd never seen that Autosmooth normals option before. Thanks for sharing that too!
Hi all, I've seen elsewhere that 3D-coat respects smoothing groups. I've been trying to get an .obj from Blender into 3D coat today, but have had not luck as far as the smoothing groups go. Of course in Blender, smoothing groups are set with edge sharpness, but the obj exporter converts these to SGs allegedly. As I'm typing this I thought to try an .fbx import, and that seems to work OK! So presumably there is either a problem with Blender's .obj export, or 3Dcoat's .obj import. For reference here are some images: my model in Blender, my export settings, and the model in 3D coat (obj). Posting my .obj here too in case it warrants investigating. Cheers! RockingHorseModelMerged&Smoothed.obj
@arumiat Not sure if this will help, but I just had a similar challenge getting from 3Dcoat to SP. My process was 1. Model in Blender (low poly, 5 objects) 2. Export .obj to 3dcoat for UV mapping. All objects on same UV set 3. Export .obj again to Substance - this gave me the 'one material' issue 4. Opened the .obj in Blender again, and add a separate default material to each object (naming them, head, eyes, hair etc.) 4. Open obj in Substance et voilá. Objects separated by material (as 'texture sets') ready for painting, and allowing for isolating parts. The obects still share the UV space as expected. Hope this gets you a bit further
3D-Coat Applink for Blender Workflow Help Needed.
Hammers replied to 3DNut's topic in General 3DCoat
I've just tried this new version of the script. Os X 10.9.5 3DC 4.5 Blender 2.74. The panel is showing in Blender OK but doesn't seem to talk to 3DC. -
[Solved] No baking from retopo to paint
Hammers replied to Hammers's topic in SOS! If you need urgent help for 3DCoat
Wow, don't know how that happened. I guess when I imported the body base mesh from Blender, but sheesh! Oh well, another gotcha to look out for. Thanks Carlosan! -
btw I'm on OSX 10.9.5 and tried this with 4.5.0.0 and previous testbuild. -
Just thought I'd start my own thread for clarity. I've done a sculpt, which has been retopoed and unwrapped, but when I try to bake it to ppp, I get a 'blank' normal map and the retopo geometry doesn't go across. As a stopgap I tried exporting my hi poly sculpt to Blender, but the export also fails. I get a lot of vertices all at the same point in space. Here is my file. I'm just trying to paint the horns. Thanks in advance. https://www.dropbox....sRetopo.3b?dl=0
