farsthary Posted November 8, 2012 Share Posted November 8, 2012 Hi I also started trying my own medicine, this is my first attempt using LC tools as an "artist". Not as spectacular as all seasoned artists here but the purpose is to spot bugs and workflow issues. will continue adding polygons and eventually will try other areas of 3D Coat. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted November 8, 2012 Advanced Member Share Posted November 8, 2012 I think it would be better to try and match a reference. You might encounter more issues(workflow,tool issues) when trying to achieve something real than creating something freeform. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 8, 2012 Share Posted November 8, 2012 Great! Quote Link to comment Share on other sites More sharing options...
Member Dirceu Franco Posted November 8, 2012 Member Share Posted November 8, 2012 Great model. Try merge objects or use curve tools for legs. From my side I didn't have success with this operations. Thanks Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted November 8, 2012 Contributor Share Posted November 8, 2012 Great model. Try merge objects or use curve tools for legs. From my side I didn't have success with this operations. Thanks This, try to convert parts in voxel then back to surface and merge them. Try to resym often with liveclay mesh. Try to use crease clay and reduce often to spot holes/tears. Quote Link to comment Share on other sites More sharing options...
Member Dirceu Franco Posted November 8, 2012 Member Share Posted November 8, 2012 This, try to convert parts in voxel then back to surface and merge them. Try to resym often with liveclay mesh. Try to use crease clay and reduce often to spot holes/tears. I'll try thanks BeatKitano. Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted November 8, 2012 Contributor Share Posted November 8, 2012 Ahaha, no I was adding to your post, to help Farsthary finding bugs Btw in english decompose is written like this "separate disconnected peaces" it's pieces Quote Link to comment Share on other sites More sharing options...
Member Dirceu Franco Posted November 8, 2012 Member Share Posted November 8, 2012 huahuahuahua.....I'm sorry for the misunderstanding. Quote Link to comment Share on other sites More sharing options...
farsthary Posted November 8, 2012 Author Share Posted November 8, 2012 Updated Quote Link to comment Share on other sites More sharing options...
farsthary Posted November 8, 2012 Author Share Posted November 8, 2012 Yes, I have found so far several issues, mostly related with other tools interacting with LC, like muscles that creates wrong normals and causes LC to explode or have flipped faces, nothing catastrophic because Reconstruct can easily correct wrong local mesh and or some on manifold parts. Will try adding and merging parts. Quote Link to comment Share on other sites More sharing options...
Advanced Member michalis Posted November 8, 2012 Advanced Member Share Posted November 8, 2012 Well done Raul! Some more crisp details on nose, eyes, mouth. Maybe. I have found so far several issues, mostly related with other tools interacting with LC You may report them to Mantis. If you can reproduce the issue. Are you gonna retopo it? Better avoid thin areas, you can make them thinner after... You can't do this in in 3dcoat? You can in blender, you may find it more capable on such cases. Quote Link to comment Share on other sites More sharing options...
Advanced Member wave of light Posted November 8, 2012 Advanced Member Share Posted November 8, 2012 Yes, I have found so far several issues, mostly related with other tools interacting with LC, like muscles that creates wrong normals and causes LC to explode or have flipped faces, nothing catastrophic because Reconstruct can easily correct wrong local mesh and or some on manifold parts. Will try adding and merging parts. Excellent to hear and see your results. When you say 'reconstruct' do you mean when using the 'CleanClay' brush? Before you start merging, please ramp up the polys, in surface mode and then try to merge something detailed, using 'merge to' or 'move to' Ricky. Quote Link to comment Share on other sites More sharing options...
farsthary Posted November 8, 2012 Author Share Posted November 8, 2012 I mean Reconstruct tool, a recent addition to LC tool set, quite powerful and useful to locally clean the mesh Quote Link to comment Share on other sites More sharing options...
farsthary Posted November 9, 2012 Author Share Posted November 9, 2012 Solved a very annoying bug, some random black spots or "fake holes" that appear sometimes after long sculpting session in LC Quote Link to comment Share on other sites More sharing options...
Advanced Member wave of light Posted November 9, 2012 Advanced Member Share Posted November 9, 2012 Hi, Where is the Reconstruct tool, or is the reason I can't find it related to the preset brush menu issue. Is there anyway to remove preset brushes from the spacebar quick menu at the top. Also, I have come across the black patch bug. CleanClay works randomly on fixing it. Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted November 9, 2012 Contributor Share Posted November 9, 2012 Solved a very annoying bug, some random black spots or "fake holes" that appear sometimes a fter long sculpting session in LC looks like you caught one culprit keep sculpting youll soon get what i've described in update thread i'm sure Quote Link to comment Share on other sites More sharing options...
