blackant Master
is there a way to import Vertex color into Sculpt room mesh ?
Hello, everything is in the title...
i'm testing some new workflow...
i did this model in Zbrush, and would like to retopo it in 3dcoat, i was wondering if this may be done this kind of way cause i never tried before, i usually only use import reference mesh so i don't use any color. But if it could be done, it could also greatly speed up some kind of works done in zbrush...
I do similar sort of stuff but usually export from 3dcoat to zbrush just to check if it will open for a client. So I will assume it will work the other way but I cant remember if I have ever done it ..
Try exporting/saving from zbrush using the FBX export . ( I think from memory its in the Plugins tab .) FBX stores the colour vertex info, where as OBJ does not.
i can say that obj is writing vertex color, because i use it with marmoset tolbag, but i never tryed using fbx for this tasks... i will check
If i am not mistaken OBJ specification does not support vertex color, some program can store this information but other software cannot read it. only option is FBX
