[Fixed] VerTextures/Fracture with Vertex Painting bug?
Go to solution Solved by Andrew Shpagin,
Hi. Is it possible to use fractures together with normal vertex painting on different layers?
I don't know whether this is a bug or that's just how it works. When I paint vertexture on a new layer then disable that layer, it seems to also wipe all color info from all layers in the fracture-painted region. If I move the opacity slider back and forth, sometimes it works, sometimes it doesn't.
Confirmed and reported, thanks for point it up.
If you paint the first layer with normal vertex painting and then paint factures over new layers on top, opacity blend works as expected.
But if you only paint any surface model using only factures, opacity blend in between factures layers is broke.
Factures provide an easy and powerful way to achieve surface detailing of practically unlimited levels.
This is the way to apply a texture without the actual UV assignment.
It works similarly to vertex painting; however, you paint with texture, not just the color.
The main rule is that you can assign a texture and a color to each vertex. Each vertex on every layer has only ONE texture. So, if you paint with texture over another texture on the current layer, the texture will be replaced, not blended. But you can apply many textures to each vertex using multiple layers with opacity. If neighboring vertices have different textures, the textures will be blended between the vertices and no seam will appear.
If you want to use the Conditions drop list, first use Calculate menu to create or update cavity or occlusion layers.
  • Carlosan changed the title to [Fixed] VerTextures/Fracture with Vertex Painting bug?
