Showing results for tags 'texture'.
Hi! I'm not absolute newbie to 3Dcoat (using it mostly for Retopo and UV mapping since 2015) but not an expert either so i need help :). Currently i can't find solution for one problem. I have 800k polys mesh (5 mil polys photogametry scan decimated in zbrush and exported with UV map) which I'm doing retopo on in 3DCoat 4.7.x (i need to do it manually since no automatic mode gives me good enough results) and all is going nice and smooth (i love Quads tool :)) except the fact i can't find way to display my main mesh (retopo background mesh) with it's TEXTURE ? I have hi poly mesh (that 800k polys) which has 8k UV map for color/normal/spec i need to see that texture in OpenGL while i'm doing retopo because some parts of mesh need polyflow based on texture colors. Is that possible somehow in 3DCoat? All i can get in Retopo room is modes from 1-9 and neither of them shows Texture on background mesh visible but different modes of grey/specular/wireframe? Thanks
Hi friends, I imported a scaned model (from photogrammetry), I painted it with several layers, and now I would like to export model to OBJ and a simple texture 8K resolution (JPEG or PNG...) to use in a scene for animation with Cinema 4D. I tryied different option to export color textures and I have only a 256x256 pix PSD with all color layers but empty. 3D-Coat is so complex and with so so many options that do a simple task like this it's no easy for ocasional users like me. Thanks in advance!
I'm having a bit of trouble getting UV's to blend at the edges. This is my best attempt - making a base mesh in C4D and auto-UV-ing in 3DCoat. I'd like some advice for making the edges blend better, or perhaps a video link. I'm on the lookout for manual UV-ing tutorials so any advice that points in that direction is appreciated. Also, I'd like to understand why the material was blank when exported - ie: the textures didn't export with the OBJ. I had to export them separately and reconstruct the material from individual maps in C4D. pillarRockTest-1-bad-UVs.tif
With the release of Renderman 21 Non-Commercial, it would be great if there were export presets. The shaders have changed a bit since the release of 20, and he old presets don't quite match up. It would be great if there were some new presets added for Renderman 21. https://renderman.pixar.com/view/non-commercial-renderman Thanks!
From the album: Monster Bash
This illustration is part of a bigger project called Monster Bash. Actually this is the first one: The Great Evil Witch from the Dark Forest. Hope to share more with you soon!- 4 comments
- 4
- character
- character design
(and 5 more)
Hello guys! I am really happy to use 3d coat and this is my favorite program for texturing, retoping and UVs, BUT For the competition i need texture atlas and i totally can't understand how to do it. I use UV room a lot, but still not very good in some functions of 3d coat. What i want - for example: i have 4 512 textures. All models have their own UV and they textured in Metallic PBR + AO. (3-5 textures for each one asset). Question - how to create 1 1024 texture for that models? I know only long way - create 1024 texture in Photoshop, past 4 textures and place UV's by hands with 0.5 scale. But I am sure that this is stupid action and there are ways which will be better and faster in 3d coat. Or may be there are another ways . Please, if it possible, link any video or write step by step. I will really appreciate help, thx
Hi there I am currently giving 3dCoat a spin and have a question for the UV room: I've created the seams and unwrapped the model successfully. The texture export also works well apart from the fact that I would like to export the UV wireframe as a reference as well (on a separate layer would be cool). I havent yet been able to do that. Any ideas on how to do this? Cheers, Michael PS: Why can I only make 2 posts per day?
Hi Im newbie on 3dcoat and trying to learn 3dcoat. is there someone that really know how to export correct settings of textures for vray for maya ? fbx exported within 3dcoat wont importing in maya2016 correctly. also I tried to generate my own shading-network in maya. but result is very bad. do you have a practical video shows how to export correctly for vray4maya and how to setup a shader and link texture nodes in maya ? it is really confusing what does it mean "texture export/import workflow" (gloss metallness, gloss specular color.. etc.) do you see a good video tutorial that teaches it ? thank you
Hello, I recently purchased 3D Coat and started my first personal test project. I opened up the software and created a model in the sculpt room, then brought it into Paint Room and painted it. At this point, I tried to save out the object with all the aesthetic data and started to run into problems. 1) Tutorials show that when you go to Export objects and textures, it is supposed to give you a popup menu of the types of maps you want to save. This pop up doesn't appear. It only allows me to save the geometry as an obj, fbx, etc. 2) So, I go to Texture drop down and try to save everything manually one channel at a time. All the tga files come out black. Any insight to fixing this would be greatly appreciated. Thanks!
I cant find any shortcuts for rotating, scaling and paning textures/stencils. Are there any? there is no tooltip for them.
При експорте материала из коата в макс/вирей материал становится совсем не таким, каким он был в 3д коате, как я понял - это из-за того что вирей не поддерживает PBR, но ведь как-то наверняка можно в вирее использовать текстуры и материалы коата... Подскажите как сделать так чтоб в вирее материалы отображались верно и как вообще рендерить модели и материалы с коата, не на коате... например как их рендерить на вирее, или может вообще воспользоваться возможностями рендера на движке вроде анреал енджина?
Hi, I'm fairly new to 3D Coat and I currently only use it to work on reskins of weapons for CS:GO but I've come across an issue that is becoming rather frustrating as I can't work out what's causing it. After opening in external editor and working on the texture then saving and loading it back in 3DCoat the program seems to sample a section of the texture and draw a line right across the bottom of the UV as seen here; http://pasteboard.co/1NlqNDGM.png this line is NOT present in the .psd file! I did not put it there! But it persists and I can't get rid of it, I don't even know what's causing it or how to stop it. I thought it might be broken faces but it's not even aligned with the faces and I HAVE used this model before with 0 issues but even the save file for that, after re-opening it in an attempt to use it because I knew it was fine before, is now suffering from this issue as well! The file is attached, it's the official ripped .obj from the game and until now I've never had issues with it nor any of the other gun models so some help would be appreciated! Also, any way to fix the problem with seams? 3DCoat deletes the texture outside the uv's boundaries leaving horribly broken looking seams which can also be seen in above screenshot. I'm on Win7 and have 4.5.19 installed. Thanks desert_eagle.obj
Hey guys, Here's my Steampunk inspired vehicle, I modeled everything using 3D Coat's Sculpt Room. Once the model was finished it was around 6-8 million poly. So I retopologized it in 3D Coat and managed to get it to about 39K poly and was really impressed. After which I textured it using the Paint Room and smart materials and rendered within the Render Room. Everything was done within 3D Coat. I'd wanted to try connecting a mix between a go-cart style unibody and a one wheeled motorcycle. Thanks for checking it out. :)
so i got 3D coat to trial out making skins for CSGO. when ever i saved the texture on photoshop it kept doing this :/ any help? thanks
From the album: FanArt
After reading Red Skull: Incarnate I decided to create a illustration. 3D Coat + Modo. Hope you liked it! -
New Tutorial!! Hard Surface UV Mapping in 3D Coat 4.5 http://www.learn3dsoftware.com/3dc_4_vol_21_hard_surf_uv_map.htm In this twenty-first video volume of 24 volumes 3D Instructor Adam Gibson goes through a project based session of Hard Surface UV Mapping of a multi-mesh layered sci-fi vehicle. UV Mapping for a lot of 3D artists can be a frustrating task. In this course easy to use work-flow tips and concepts are discussed and demonstrated to get you UV Mapping your 3D models quickly and efficiently. *Bonus: Content Folder Included. Table of Contents for Volume #21 Chapter 1- Intro Chapter 2- What is Hard Surface UV Mapping? Chapter 3- 3D Model Preparation Tips and Gotchas Chapter 4- Breaking Up Model Layer into Easier to Unwrap Pieces Chapter 5- Importing Model Into 3D Coat & Surface Materials/Paint Objects Visibility Chapter 6- Interior Compartment UV Unwrap Chapter 7- Exterior Compartment UV Unwrap Chapter 8- Rear Hatch Plate UV Unwrap Chapter 9- Front Wing Rotators UV Unwrap Chapter 10- Front Wing Thrusters UV Unwrap Chapter 11- Front Wings UV Unwrap Chapter 12- Upper Laser Cannons UV Unwrap Chapter 13- Lower Laser Cannons UV Unwrap Chapter 14- Cockpit UV Unwrap Chapter 15- Tail Fin UV Unwrap Chapter 16- Rear Wing Thrusters UV Unwrap Chapter 17- Rear Wings UV Unwrap Chapter 18- Rear Wing Rotators UV Unwrap Chapter 19- Rear Compartment UV Unwrap Chapter 20- Tail Fin Support UV Unwrap Chapter 21- Cockpit Nose UV Unwrap Chapter 22- Top Cap Panel UV Unwrap Chapter 23- Compartment Doors UV Unwrap Chapter 24- Rear Fins UV Unwrap Chapter 25- Export to UV Unwrapped Model to Lightwave Chapter 26- Final Running Time: 4 hrs. 4 mins. High Quality (Screen-Res 1920 x 1080 pixels) Video Format: MP4 (.mp4) Level: Beginner
- uv mapping
- texture
- (and 6 more)
Hi guys I really had an idea of creating something for Dota 2 workshop and I decided on a courier. I am familiar with softwares like 3ds max and 3d coat but I am a casual user and i don't understand some parts to do it till the end. Q1: How should character look? Should i split the parts of body of courier (legs, hands etc...) or I keep it as one part? Q2: What is the workflow? Dota 2 courier asks for max 3000 polygons model which is very low. I just don't understand how can you keep the details of the courier, but guys on workshop somehow does. When i try to retopo my high poly model into fewer polygons i just can't menage the details. Q3: I know that you somehow have to apply texture from high poly to low poly mesh but I don't understand how and there is not enough information online? Q4: I want to export model from 3d coat to 3ds max to animate, but when I do that materials dont apeear to be right, how to adjust it inside? I hope you guys can help and others who has similar ideas to create something for workshop can learn, feel free to send any links that might help, but personally I didn't find any real source of info that really explains everything step by step ( for dummies ) Thanks a lot!!!
Is there a way i can replace the checker grid/texture on my retopo mesh, with a custom texture. Edit: ah found it. select mark seams tool, and you will see a box defaulted as "simple checker" (in the tool options box along the top of your screen), drop down the list and select custom checker.
From the album: Javis' Works
Finished textured model of the U.S.S. Defiant NX74205 from Deep Space Nine. Modeled in Modo, textured in 3D-Coat (and a splash of Photoshop).- 5 comments
- 3D-Coat
- Mesh Fusion
(and 6 more)
Здравствуйте, обитатели форума 3D coat, недавно перешел на новую для меня версию программы 4.5.02. И заметил в новых фичах обидную проблему. Есть модель с текстурой 2048Х2048. И превью материала показывает мне такое качество: Я радостно беру кисть и получаю на выходе вот такое : И еще раз для сравнения: Прошу объяснить, из какой жопы у меня растут руки, и что я делаю не так. Вот еще UV, авторазвертка, может в ней проблемы?
Hello 3D Coaters! Is there a way to export a model to keyshot and have your vertex paint show up (no UVs)? In keyshot I can see the model but no texture. I know how to do this in blender (export as fbx, and plug in the 'Col' etc) but is there a way to do this with keyshot? My goal is to find a UV free workflow. Any knowledge cakes will be appreciated!
Hey Guys, Were having a Super Halloween Special at LEARN3DSOFTWARE.com. -Lifetime Memberships are 50% Off -Only $249 US (Reg.$499) Until October 31st!! -Training for 3D Coat, Lightwave, ZBrush, Modo, Substance Painter, and DDO training. -One Time Fee and you get Access to All New and Older Tutorial Releases!! -Over 157 Video Titles and More Being Added Every Month!! http://www.learn3dsoftware.com/membership_lifetime.htm
Hello and nice to meet you all fellow artists! I have a set of hand painted texture I have made from photoshop and need to be applied to a collection of buildings. These include textures for walls, roofs, wood, bricks etc that can be applied to parts of buildings. I would like to use a similar tool from photoshop called clone pattern if theres one in 3d coat? Or is there another method you might use to ease the process than using the brush tool and apply your textures as stamps? Thanks in regard!
- clone pattern
- photoshop
Hi there ! I'm a long time Blender/Gimp/Krita user but I'm quited tired of blender's texture painting... No layers and all.. It's been troubling me for a while. So I made my first steps to 3D Coat a few days ago and I love the app so far. Two things are bugging me though : 1 - I googled a lot and tried a lot of options ("paint through") and all but I can't seem to get the behavior I'd like with the brush concerning clipping faces. I'd like the brush to paint everything under it, and not just snapping on a particular polygon. Is it possible ? 2 - I googled that already and it seems there isn't but I'm still asking... who knows Is there a smudge/smear brush in texture painting ? Thanks a lot for your help ! Regards, Ghislain.
