How does 3DC sculpting compare with zBrush?
MarkG
I was curious what kind of response rate you all are seeing with 3DC when sculpting detail into an existing mesh. I am not referring to Voxel sculpting, because I don't think it will work for what I want... though if I am wrong, I will be happy to be corrected. :D
I want to take a low-level mesh built in Silo, and bring it into 3DC to create detail... When finished, I want to export that out as either a normal or a displacement map, and then render the whole thing in another program (Messiah).
I can do this in zBrush. How does 3DC compare with this workflow?
I know that zBrush sort of "cheats" when it comes to polygon count. (meaning they do not do a full 3D representation of the object, but rather have their special 2.5 D mode...) so it will always be able to push higher polygon counts.
But, what kind of polygon counts are you able to use in 3DC -- version 3.0. (And, if you could also give your machine stats, that would be helpful...)
Thanks!
I have used Zbrush before and mostly I got stuck on hands and feet.
Voxelpainting gives you a lot of freedom,most comparable to building with clay.
When you've finished your voxel you can do an automated retopo,or do the topo yourself in the "retopo" room.
Basically you could import your zbrush obj file and retopo it there as well.
The retopo works very fluid and is not complicated to learn.,here you can go back to low poly,or any polycount you choose.
A little knowledge on how polygons and topology work is still needed for that.
The Autoretopo gives a useable mesh but might not have its' poles or folds where you need them.(you can also choose a meshresolution before the autoretopo is generated,high or low poly.)
Difficult areas like nostrils and such are much easier to do now I think.
Anyway hope that helped a little.
Silo->3d-Coat path is my workflow for the most part, and it's quite effective for me thusfar.
If you are fine with a more limited sculpt capability (but still higher than Silo's 1-2million polys)
in terms of brush tools within 3d-Coat and focus on using the 'Sculpt' room for forms and shape control,
then using the 'Paint' room for your high-level detail, you won't be disappointed. 3d-Coat certainly
doesn't have the sculpting toolset Zbrush has yet (nor the feel of polish with the brushes). Nice thing
is that you can work back and forth between 'Paint' and 'Sculpt' if/when you need to without incurring
too much warping of your detail (say, for instance, you wanted to adjust a sleeve that's got a woven
detail already applied to it). Also, you can fully erase out your detail if you need to without having to
think about creating a prior morph-target (or go through special dances with layers ala Zbrush). Things
like 'Draw with Splines' and all of the other 'Paint' tools are also additional icing on the cake (lots of
goodies that folks forget like being able to hover your 'Pen' over an area and ctrl-c whatever is underneath
and ctrl-v it somewhere else). ;)
I like to have at least 4mil polys when micropainting and keep to 4096 or 2048 for textures (which can
be dropped in size later). Filesize when saving a .3b 'project' file can be quite large.
In terms of the process of creating the normal or displacement map, you are doing it as you sculpt, so
it's fast to export the texture files out (or bake them down to your lowpoly)...it's not like you have to
wait for the normals to be created in the fashion Zbrush does with Zmapper or via the Tool->Displacement
panel.
I haven't tried to push my polycounts with micropainting any further than 6mil so far. With voxels, I can
still work on 24mil objects (up to version RC 3.00.3...haven't upgraded yet) but large brushes and navigation
are pretty slow (Andrew has potentially fixed this with 3.00.4 or 3.00.5 but I haven't been able to check yet).
My system specs are in my sig. Hope it's of some help. :)
i want to get both, and zb4 is a free upgrade they say? i wonder if zb4 would have anything voxellish?
havent pushed the latest release of 3D coat voxels at all yet but I have got up to about 6 million triangles without much slowdown at all
I have used ZB but couldn't bare to use it for any length of time, I barely got through one of the tutorials on their site. However in 3DC I was able to sculpt a character with lots of wrinkles including sculpting fine detail in the voxels like pores and prints on the skin. Then I retopologized it and baked the normal map. After that I painted the textures in 3DC and I was able to export it to LightWave for rendering with textures, normal maps, and displacement maps. And I had fun through the whole process.
I have used ZB but couldn't bear to use it for any length of time, I barely got through one of the tutorials on their site. However in 3DC I was able to sculpt a character with lots of wrinkles including sculpting fine detail in the voxels like pores and prints on the skin. Then I retopologized it and baked the normal map. After that I painted the textures in 3DC and I was able to export it to LightWave for rendering with textures, normal maps, and displacement maps. And I had fun through the whole process.
are you able to bake the details you had in voxel like pores and prints and bring it back to painting/sculpting mode. Do we have that feature yet? :yahoo: I've only used 3dc for painting and sculpting. Havn't touched voxel much really.
Yes, "Quadrangulate and paint" and "Quadrangulate for per pixel painting" these tow commands can do this. Or you can also manually retopo and then merge into scene, the details from voxel will be baked to the map.
So voxel details can be exported out as displacement maps now? When I quadrangulate I get a loss of detail. Is it possible to bake the voxel detail and use that but not the high poly quadrangualted mesh?
