Contributor 3d_sculptress Posted October 7, 2009 Contributor Report Share Posted October 7, 2009 Okay, now I have a new problem...Yes more. I got it to go in merge for per-pixel paint with normal map just fine but for some reason, I get a hole in this one area and it has a yellow line in retopo, which has know faces, which is strange..Any clue? There is no hole in voxels as you can see from the second pick.. personally i think if you'll smooth out the 'hump', then try retopo n merge for perpix again... it will be ok ..no gurantees of course. ... 'edit' to be more specific, ..look inside the yellow square, do you see the 'gray shadows?..that's the area i would smooth out in the 'hump', so it wouldn't be as creased... Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 8, 2009 Author Advanced Member Report Share Posted October 8, 2009 personally i think if you'll smooth out the 'hump', then try retopo n merge for perpix again... it will be ok ..no gurantees of course. ... 'edit' to be more specific, ..look inside the yellow square, do you see the 'gray shadows?..that's the area i would smooth out in the 'hump', so it wouldn't be as creased... I smoothed some of the hump out but I still got the same problem the yellow line that you see which I have circled, are causing to have a hole in paint exactly where you see the yellow lines in retopo. which will not go away.. Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 8, 2009 Author Advanced Member Report Share Posted October 8, 2009 Here is my crappy model no texture, pieces missing, burnt in I don't know what!! I did a quick render test in Lightwave to see what if anything would come out . Very discouraged at this point in trying to get this thing to work. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted October 8, 2009 Contributor Report Share Posted October 8, 2009 Here is my crappy model no texture, pieces missing, burnt in I don't know what!! I did a quick render test in Lightwave to see what if anything would come out . Very discouraged at this point in trying to get this thing to work. Can you post your file here? (you can use www.sendspace.com) I will fix it for you within 30 minutes . Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 8, 2009 Author Advanced Member Report Share Posted October 8, 2009 Can you post your file here? (you can use www.sendspace.com) I will fix it for you within 30 minutes . I really need to get this fixed on my own which I'am still doing at this point and still have alot to learn. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted October 8, 2009 Contributor Report Share Posted October 8, 2009 Here is your file,corrected http://www.sendspace.com/file/t728kt It seems there was a lot of junk from previous bakings left in the Paint room (to avoid problems when rebaking you need to clear previous objects and layers from Objects and Layers tabs in Paintroom) Btw ,baking was already pretty good there was just 1 artifact on the right hip of the character. Now Baking is perfect,no artifacts whatsoever. It took around 10 seconds to bake. This is your voxel sculpt ready to paint. (3DCoat normal map is as sharp as Xnormal) (I used 2048 so if you want to rebake with 4096,just clear objects and layers from Paintroom tabs and bake again) Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 8, 2009 Author Advanced Member Report Share Posted October 8, 2009 Here is your file,corrected http://www.sendspace.com/file/t728kt It seems there was a lot of junk from previous bakings left in the Paint room (to avoid problems when rebaking you need to clear previous objects and layers from Objects and Layers tabs in Paintroom) Btw ,baking was already pretty good there was just 1 artifact on the right hip of the character. Now Baking is perfect,no artifacts whatsoever. It took around 10 seconds to bake. This is your voxel sculpt ready to paint. (3DCoat normal map is as sharp as Xnormal) (I used 2048 so if you want to rebake with 4096,just clear objects and layers from Paintroom tabs and bake again) Thanks Artman appreciate it.. Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 9, 2009 Author Advanced Member Report Share Posted October 9, 2009 Missing parts when loaded into Lightwave any Ideas what is causing it? Retopo? Looks fine in 3dcoat.. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted October 9, 2009 Report Share Posted October 9, 2009 Are you sure they're missing and not just flipped or hidden? I see you're using the old Subpatch mode, have you tried Catmull-Clarke? Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 9, 2009 Author Advanced Member Report Share Posted October 9, 2009 Are you sure they're missing and not just flipped or hidden? I see you're using the old Subpatch mode, have you tried Catmull-Clarke? Yeah they are completely missing.. Andrew said he was coming out with another update to address some of the issues I had today so keep your eye open.. You are the man Andrew!! Andrew wrote this: And to solve it finally, I will merge separate grouls to separate surfaces, not separate objects(layers) as it is now.I will post new build very soon- today or tomorrow. I fixed bug that prevented merging to microverts, but really result of merging to DP is much much much better,And I have not found a hole in retopo - all looks beautiful. I uploaded 3.1.10. Try it. Your the man Andrew!! I had seperate retopo groups which was causing blank spaces in Lightwave, once I combined the retopos as one group it all worked out fine.. Now I got it down thanks for the help guys!! Now to go back and redo it to make it better.. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted October 9, 2009 Report Share Posted October 9, 2009 Not to be the big bad admin, but could you try to avoid double posting? If yours is the last post, just edit it. Quote Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted October 9, 2009 Advanced Member Report Share Posted October 9, 2009 Thanks! Quote Link to comment Share on other sites More sharing options...
Contributor 3d_sculptress Posted October 15, 2009 Contributor Report Share Posted October 15, 2009 Here is the final which the animation is going to be really short for this and be shown from the back 3/4 side. It is not great but not bad.. hi Scott...looks fantastic ! Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 15, 2009 Author Advanced Member Report Share Posted October 15, 2009 Thanks Sculptress.. I removed my post from above. The feet will not be seen in the animation which will be very short for this character. I need to go back and fix a few things but here is the renderings again.. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted October 15, 2009 Contributor Report Share Posted October 15, 2009 Nice job, Scott! Very Art Deco. Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted October 15, 2009 Author Advanced Member Report Share Posted October 15, 2009 Nice job, Scott! Very Art Deco. Thanks Tony.. Quote Link to comment Share on other sites More sharing options...
