Blender Applink "Simple3DCoat" (Fork of the official) by mifth
mifth
Hi all,
Simple3DCoat addon is for Blender+3DCoat production. This is a fork of the official one made by Haikaikalle .
Blender 2.93+
3DCoat4+
Features:
  • Set the Exchange Folder of 3DCoat manually.
  • Custom Textures Path for export/import.
  • Export/Import through Obj/Fbx formats.
  • ExportMaterials, ApplyModifiers checkboxes.
  • No PBR Materials support. Sorry.
  • Simple to Use :)
Screenshots:
How To Use:
- Enable the Addon and set the Exchange Folder.
- Export/Import models back and forth. :)
Download:
Sources: https://github.com/mifth/mifthtools/tree/master/blender/addons/2.8/io_simple_3dcoat
Latest MifthTools Master Download (ZIP): https://github.com/mifth/mifthtools/archive/master.zip
Enjoy.
  • Thanks 2
  • 2 weeks later...
Is there a way to get this to work?
I've tried both the default add-on, and this one, on both Windows 7 and Mac, and neither one of them do what I thought it would do.
It does export the model to the directory I selected, but it does NOT launch 3d-coat.
Am I missing some sort of setting that needs to be changed in 3d-coat itself?
As @carlosan said you need to open 3DCoat.
And Exchange directory should be set correctly. In Windows it should be "Documents/3DCoatV4/Exchange". And you should save Exchange directory with Ctrl+U. I'll make a video tutorial soon.
Edited by mifth
Yes, a video tutorial would be great, because I always have problems getting addons to work.
Well, I sort of got it working.
I found that the choice I was making, voxel primitive, didn't seem to work, no matter whether 3D-coat was opened, closed, whatever, even though all I had open in blender was the default cube.
It will export the .obj, but nothing shows up in 3D-Coat if you make that choice.
If I choose pixel painting, it works well though.
Do I have to clear the model out of the folder to export another model?
I also couldn't seem to get it to work completely with other voxel settings, and the scaling of the object in 3D-Coat seems to vary with what choice you make for export, which seemed weird, should be the same .obj I would think.
Possibly this will help you:
  • 2 months later...
This was working for me in Blender 2.69 but here on the eve of 2.70 (2.69.11 is precisely my build) - Simple is no longer working for me, but the original applink does still. I'm on Windows 8 64bit using 3D Coat 4.0.16
I have 2.69.11 Linux build. All works ok. Do you get any error when press "ExportObjects"?
- Make sure you set Exchange folder in the addon settings.
- Try to get latest sources from here https://code.google.com/p/blender-addons-by-mifth/source/browse/#hg%2Fio_simple_3dcoat
  • 1 month later...
Hi
Is working fine for 2.70 and 4.1 ?
ty
Hi
ty
The script work ok for 2.70 and 4.0.15B. There is still no 4.1 for linux. But i guess everything is fine. :)
Edited by mifth
  • 4 months later...
  • 5 months later...
Hello there :),
I have the problem, that Blender is just not able to find the exchange folder. I set it to Documents/3DCoatV4/Exchange , bust just nothing happens. I´ve 3dCoat also opened. Can someone please help me with this??
I´m jusing Blender 2.73 , and 3D Coat 4.1.17 educational on Win7
Hi!
Texture patch is set ?
post-10142-0-17247500-1423227666_thumb.j
Exchange folder is set the full path ?
C:\Users\User\Documents\3D-CoatV4\Exchange\
  • 2 months later...
  • New Member
All I'm getting is "No selected objects or bad excange folder!!!" Exchange folder is set and I tried removing every UV-map, material, texture, vertex group and armature and still the same message.
If I start a new project and export the 'default-cube' it works OK.
  • 1 month later...
The add-on installs ok for me. I change the exchange address, but the drop-down doesn't appear unders SCENE. If I uncheck "Simple" and check "3d-Coat Applink" it shows up. Blender 2.74 / Both Mac & Win8.1
I moved it into 3dViewport T Panel.
I am having a problem where if I export an object from Blender to 3D-Coat using Simple3DCoat Applink and the Mesh As Voxel export type, then when it imports it comes in with the last imported object's transform, rotation and scale.
Here is a video explanation of the problem that I am having.
Why is this happening? Where is the info being stored that tells 3D-Coat to import with the last used transform, scale or rotation and more importantly, how do I clear that data so that I can start fresh?
Thanks for your help,
Bryson
  • 3 weeks later...
Bryson
Dunno know. Try to press ResetOrigin in 3dc when you import the model. Or download latest version of 3dc.
Here is my test:
  • 2 weeks later...
I am using Blender 2.75a and 3dcoat 4.5.03  I enable the add-on ver. 3.521   does this ver work with 2.75a ? it seams broken on both ends . any help/direction would be helpful .ty
The addon was moved to Scene Tab
Isnt there anymore ?
Yes its there but shorter as in just Export type (DROPDOWN) list and 2 buttons Update and Transfer. All the rest that use to be there is gone as in / apply modifiers,texture path,export type, im thinking I need to set the exchange folder to 4.5.03a ? IN 3DCOAT there use to be a option when the app-link was set in the drop down list under file I think to send it over. As long as I know the app-link works with these 2 versions I will keep at it. Thanks for your time Carlosan
I think you enabled the official addon. You need to enable Simple3DCoat addon from here https://github.com/mifth/mifthtools/tree/master/blender/addons/io_simple_3dcoat
do I have to sign up at github in order to copy the simple_coat.py   and yes I have the official add-on so I will uncheck it and do this one thanks mifth for your time helping.
Using Blender 2.75A , 3DCOAT 4.5.07  Mesh for Auto retopology crashes 3DCoat.
https://github.com/mifth/mifthtools - you can download zip archive at the right corner. See the big button.
Possibly this is 3DCoat issue.
It appears to be pulling up an older Retopology. There also is no option for Hardsurface Retopology. It is referencing and older 3Dcoat version.
