modo AppLink
  • Please log in to reply
29 replies to this topic
#21 bona
bona
    Newbie
  • 17 posts
Posted 30 August 2013 - 01:32 PM
Hello all,
I'm using V4 and Modo 701 Sp2 on OS X 10.8.4
Installation works fine, just need some minor changes to get it work in ML, thank you for the script  :)
Here're the steps:
( After installation, pls find these 2 files in /Users/[YOURNAME]/Library/Application Support/Luxology/Scripts )
In both "3dc_applink.py" and "3dc_applink_auto.py",  comment out these 3 lines :
# SYSTEMDRIVE = os.environ['SYSTEMDRIVE']
# USERNAME = os.environ['USERNAME']
# HOMEPATH = os.environ['HOMEPATH']
Then add these 2 lines right after the above comments:
SYSTEMDRIVE = ""
HOMEPATH = os.environ['HOME']
Now use your editor's find/replace function to replace all "\\" with "/" (without quote)
Also find and remove all "/Documents" (without quote)
File path codes in both files should changed from this:
'\\Documents\\3D-CoatV3\\Exchange\\'
to this:
'/3D-CoatV3/Exchange/'
Last step, because I'm using V4, I changed all '3D-CoatV3' to '3D-CoatV4' in both files.
If you're using V3, you probably need to skip the last step.
Enjoy! :rofl:
#22 q313923011
q313923011
    Newbie
  • 5 posts
Posted 04 September 2013 - 11:18 AM
why dont put ur script in here,i have change ,but not work
#23 bona
bona
    Newbie
  • 17 posts
Posted 05 September 2013 - 10:50 AM
Attached are the edited files for OSX 10.8, only tested with OSX 10.8.4 + 3DC V4 + Modo 701 Sp2.
After installation, pls find these 2 files in your script folder with same names and replace them.
My procedure of using the AppLink is like this:
1. Make my model in MODO
2. Run 3dc_applink.lxm ( or click on the button/form you've mapped '@3dc_applink.lxm')
3. Choose export type, click Export to 3D-Coat, save the .obj
4. Switch to 3D-Coat, Import dialog appeared, choose import options and click ok.
5. After edit, choose File>Open in original app, choose export options and click ok.
6. Switch to MODO, run 3dc_applink.lxm ( if it's not running )
7. Click Import from 3D-Coat
Pls note that some people skip step 5 and use Export to Modo from file menu without success but in my testes it seems ok to do so.
All credits goes to the original makers of these Applinks, cheers.
Attached File  edited for ML.zip   7KB   127 downloads
:rofl:
Edited by bona, 05 September 2013 - 11:33 AM.
#24 q313923011
q313923011
    Newbie
  • 5 posts
Posted 06 September 2013 - 10:55 AM
i am sorry,mine is win8 system 0.0 still not work
#25 q313923011
q313923011
    Newbie
  • 5 posts
Posted 07 October 2014 - 03:06 PM
modo 801 sp2 right now,and 3dcoat 4.1 anyone can write new plug?
#26 Elowan
Elowan
    Neophyte
  • Pip
  • 83 posts
  • Gender:Male
Posted 19 December 2014 - 02:00 PM
We´re on SP3 right now ....
#27 carlosan
carlosan
    Master
  • Custodian
  • PipPipPipPipPipPip
  • 5,410 posts
  • Gender:Male
  • Interests:Character Design, Drawing, Sculpture, Modeling, Texture Paint.
Posted 30 December 2014 - 01:26 AM
Here's a link to both the installer and the manual installer:
https://drive.google...Zzg&usp=sharing
  • Javis likes this
My Blogfolio
Google+ link
3DC Google+ Community
#28 wensk
wensk
    Neophyte
  • Pip
  • 21 posts
Posted 16 March 2015 - 05:33 AM
Hello, it can run in 801 sp3 but has some errors, 3d coat can't export normal map into 801.
In 801 if click "import from 3d coat", there will bump a menu shows error information,
I'm using 3d coat v4.5.
#29 Nedsch
Nedsch
    Newbie
  • 13 posts
  • Gender:Male
Posted 06 May 2015 - 09:59 AM
Hi there,
I asked in the Modo forum, but no answer. Ich want to install the modo applink. But I'm confused who to do this.
It would be great if anyone could explain step by step what to do.
I downloaded several files. What to do with all these files? What are the applink_auto.py and the applink.py are good for? Is the install.py not enough?
I'm on a Mac (10.9.5) with Modo 801 and 3D Coat (4.1.17D)
Thanks.
#30 RabenWulf
RabenWulf
    Novice
  • PipPip
  • 131 posts
Posted 06 May 2015 - 11:58 PM
Might need an update for SP4
