New Trees?
Guest Lottmedia
Guest Lottmedia
Not to seem ungrateful for the meteoric advance of 3DC, but when are we gonna see an update to the tree generator? I just love it.
Casey
Guest Lottmedia
PS, and could somone please tut me how to make the leaves (boards) work? I can't remember if it's a clipping mask or transparency or what, it's been a while since I've used billboards and even then I was flaky with them :)
C
Now, before 2.10 speed of work becomes simply mad. So I have no time to update tree at least until 2.10.
If you have concrete requests, please write it there. I can open sources of trees generator, if someone wants to develop it I will appreciate.
If someone will make tutorial, it could be really good. Leafs problem seems to be solved at least for render, so tutorial is really required.
  • 5 weeks later...
C
I asume that we are talking about using the trees in LightWave. Just save out the tree with the button 'AutoSaveToOBJ(separate leafs)', now load the object into Layout and apply a UV clipmap using the transparency map(you may have to invert it to get it to work properly) now set the leaf surface to double sided and render.
  • 2 weeks later...
Andrew - I sent you an email, but I'll post here as well.
I'm working on a project where I need to show a tree growing in XSI. I've tried a few methods and haven't found anything that really works well.
Is there a way to get the tree generator to output something like morph targets? Programs like XFrog will generate a sequence of OBJs, but XSI loads them all into memory which can be too much to deal with.
XFrog does a good job of "growing" a tree, but the interface is pretty terrible. I'd love to be able to use your tree generator for this project.
Paul
paulrus...were you aware of this product as well?:
http://simartom.com/index.php
(native tree generator inside XSI, so you could keyframe
your creation as it's 'grown' I'd imagine...prolly need the
pro version for that, but it's reasonably priced.)
Yep - I've played with T-Gen. The problem with it is that it doesn't actually "grow" the tree, it just scales it up. So, while it can create very nice finished trees, it does a really poor job of creating that time-lapse look I'm going for.
Thanks!
Paul
There is no problem in making growth stages - just tweak parameter "Branch to root relative size" in several levels.
It is not easy to get morph targets because of optimisation of objects - try to set "Curving threshold for optimisation" to 0. But tree will be slightly hi-poly in this case (10-20 k of polygones).
  • 1 month later...
Am I missing something here? I am using V2.10.10, and I don't see any tree generator. Am I not looking in the right place?
Thanks.
Hello Shadow,
Tree generator is free for everyone who has purchaced 3D-Coat. You can download it from here:
http://3dbrush.kriska.hvosting.net/forum/i...t=0&start=0
  • 1 month later...
Not quite trees, but this is a cool little freeware program that will grow ivy around an object. I haven't tried it personally, but I think I read people saying it was easy to use and had no problems.
http://graphics.uni-konstanz.de/~luft/ivy_generator/
This video may be helpful to anyone growing trees for LW:
ftp://ftp.newtek.com/multimedia/movies/LW_9/Fiber_Leaves.mov
-Oliver
BTW I used this technique to make some vines for a recent project and it worked really well.
