Member rosikowski Posted February 14 Member Share Posted February 14 (edited) Hi guys, so Im writing this message because after 2023.16 version Im experiencing constant crushes and freezes, but its only happening when Im using: Sphere tool, with Voxel Hide and Split (crushes occur only when Im using my keyboard shortcuts (I have set Z,X,C,V,B,A for strokes modes (rectangular, Ngon, Sphere, Curves, and so on, and 1,2,3,4 for move, sphere, vox hide, split etc....) Im using 3dcoat with this worklfow for a pretty long time, so Im quite fast with this, so the faster I press those keyboardshortcuts the faster the crushes occur.... another "but" - when Im using different workflows (for example only painting with 2d paint tool and primitves tool - its fine, no crushes at all) .... another thing sometimes 3dcoat freezes in a way that it wont let me choose different tool or different stroke mode with keyboardshortcut, but I can open a menu and choose it, then it unfreezes, (so only 2023.16 version is stable for me, I was waiting for the bug to disapper with newest version but it just didn't happen, and now I could really take advantage of a live boolean tool ) cheers ! and thanks for assistance Edited February 14 by rosikowski Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 14 Share Posted February 14 Please roll back to a more stable version. 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 14 Author Member Share Posted February 14 I have alredy try all the versions above 2023.16, the last stable version for me is .16 Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted February 14 Share Posted February 14 This post was recognized by Carlosan! Oleg Shapov was awarded the badge 'Great Support' and 1 points. 2 hours ago, rosikowski said: Hi guys, so Im writing this message because after 2023.16 version Im experiencing constant crushes and freezes Hello! Please send a crash report using the feedback form that opens immediately after the crash. If you can give a list of steps so that you can repeat the crash, it will be even better. 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 14 Author Member Share Posted February 14 ok I will record the screen and repeat the process leading to a crash, (I cant send you crash report becouse it just closes without any window pop-up, or freezes for a long long time) Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 14 Reputable Contributor Share Posted February 14 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. 31 minutes ago, rosikowski said: ok I will record the screen and repeat the process leading to a crash, (I cant send you crash report becouse it just closes without any window pop-up, or freezes for a long long time) Can you try to open the app and test an empty scene with something from the Splash Screen? If it doesn't crash, then it points to the file possibly being corrupted. In which case, you should send the file to support@pilgway.com, so they can try to test it on their end and see what the problem is. If it crashes even with a simple test scene/object from the splash screen, then there is something corrupted with the install or an xml file in the MY DOCUMENTS/3DCOAT directory. If that is the case, give that directory a temporary name and Install 3DCoat again > launch the app. It will create a new folder in that directory. If it stops crashing after that, then yes, it was either the install or a bad file. 2 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 15 Author Member Share Posted February 15 (Bare in mind that when Im using 2d paint tool with brushes stroke mode, there are no crashes !, its only happening with rectangular/N-gon stroke mode, and when Im using numbers on my keyboard, maybe hotkey file is corrupted ? (Im attaching it in this post)... AbnRanger - its happening always, in every file/scene, and I did try to make a clean install still crashingfirst video with audio commentary (Im explaining my worlfow that couses the crash, althought no crash in this one, only glitches you are about to see)https://drive.google.com/file/d/1RPLTFn5OsvscLrFCFF8JKFnVAtUSQ3In/view?usp=sharingsecond one (no audio), crash at 14 minutes https://drive.google.com/file/d/1xNkRLyxlcu9pUjZ_3WLHATzaJpGcrdMe/view?usp=sharingthird one, long one (I dont expect you to watch it, maybe you`ll want to take a look at what Im doing before the crash, (using sphere/voxhide/posetools, with 2,3,4,w hotkeys) first crash after 31.30 minute, second crash after 55:00 minuteshttps://drive.google.com/file/d/104jhQ21aJHuH9UYFYiL_YV_ttK4KUYtJ/view?usp=sharing rsx_hotkeys_2024.hotkeys Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted February 15 Share Posted February 15 1 hour ago, rosikowski said: Im attaching it in this post I downloaded and installed your hotkeys. But during the work I did not find any freezes, much less crashes. There may be a problem with your file. 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 15 Author Member Share Posted February 15 Oleg_Shapo - problem with my file ? you mean the .3b project file Im working on ? (if I understand You correctly then no, Im experiencing this glitches non stop, since the release of 2023.27) and I was always checking every next version with multiply projects I was working on, and I was always rolling back to 2023.16... maybe my file as in installed 3dcoat files are corrupted ? I alredy tried to do a fresh install as AbnRanger suggested, but no luck, maybe I should completely clean every trace of 3dcoat on my system in windows registry ? Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted February 15 Share Posted February 15 1 hour ago, rosikowski said: maybe I should completely clean every trace of 3dcoat on my system in windows registry ? Let's wait for advice from more experienced users. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 17 Reputable Contributor Share Posted February 17 On 2/15/2024 at 2:16 PM, rosikowski said: Oleg_Shapo - problem with my file ? you mean the .3b project file Im working on ? (if I understand You correctly then no, Im experiencing this glitches non stop, since the release of 2023.27) and I was always checking every next version with multiply projects I was working on, and I was always rolling back to 2023.16... maybe my file as in installed 3dcoat files are corrupted ? I alredy tried to do a fresh install as AbnRanger suggested, but no luck, maybe I should completely clean every trace of 3dcoat on my system in windows registry ? I had a similar problem a few years ago, and I was very frustrated as well. Since this problem was not happening on Andrew's (Owner/Chief Developer) side, I knew there was something on my system that was causing it. I made sure to update my video card drivers and then I made sure to put the 3DCoat.exe (in the Install directory, ie. Program Files/3DCoat 202X/3DCoat.exe) on the Windows Firewall and my Anti-Virus exception list. It turns out that the Anti-Virus app I had (Avast) was the cause of the crashes. It never blocked 3DCoat before, but for some reason, it started to this time. After I put 3DCoat on the Exception/Allow list, the problem was gone. If that doesn't help, send one of your scene files to support via the HELP Menu > send support@pilgway.com an email explaining the situation and remind them that you already sent them your work file. I would put CONSTANT CRASHES in your email title, so Andrew can see that it is an urgent matter and respond ASAP. Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted February 17 Solution Share Posted February 17 I see there was no crash reports? They are really useful, I may understand all in depth... 1 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 17 Share Posted February 17 And I fixed countless amount of bugs in 2024.07 (comes today), please check it there (when released). 1 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 20 Author Member Share Posted February 20 thank You guys I have tested adding 3dcoat to windows firewall exceptions, didnt work, I`ll test the .07 version, thanks, I`ll let you know how it goes 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 21 Author Member Share Posted February 21 (edited) Im rolling back to 2023.16, 2024.07 is crushing, , same thing, freezing and shortly after crushing only when Im using rectangle and vertex lasso stroke mode with vox hide and sphere tool, not sure what else I could do Edited February 21 by rosikowski Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 22 Share Posted February 22 As I saw, the crash happens on every object scaled but not freeze on volumetric space proportions Press RMB over any object that show that red text on the lower left viewport and select the command Hope this help 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 28 Author Member Share Posted February 28 2024.13 - still crashing, first crash after 5 minutes Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 28 Share Posted February 28 Hi Are you sending crash reports? It let dev team understand all in depth. Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted February 28 Author Member Share Posted February 28 unfortunately there are no crash reports 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 28 Share Posted February 28 <- Reported to dev team again. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 22 Share Posted May 22 Is this issue solved on latest version ? 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted June 1 Author Member Share Posted June 1 nope, I was trying latest versions few days ago, crashes still happening for me Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 1 Share Posted June 1 Have you done a fresh install? Or did you install the new version over the previous one? When you have a crash, did you send the crash report? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted June 2 Share Posted June 2 On 2/21/2024 at 7:04 PM, rosikowski said: Im rolling back to 2023.16, 2024.07 is crushing, , same thing, freezing and shortly after crushing only when Im using rectangle and vertex lasso stroke mode with vox hide and sphere tool, not sure what else I could do Have you seen this message sometimes? In some cases huge object still may be created in case of improper plane position. I can't reproduce it, but may it be the reason in your case? 1 Quote Link to comment Share on other sites More sharing options...
Member rosikowski Posted June 3 Author Member Share Posted June 3 nope, never saw that, I also never had a crush becouse accidental huge objects creation, my pc only slowed down dramaticly for few minutes, 1 Quote Link to comment Share on other sites More sharing options...
