Member Adamek Posted March 23, 2010 Member Report Share Posted March 23, 2010 What are these new red lines that follow me as a sculpt voxels? I am using OSX, just downloaded the new beta. Thanks I'm joining to above question. Those red lines appear only during 'increase' option enabled. My second (strange) thing that I'd like share with others and it is related to 3D Connection is the problem with buttons. In my Space Navigator they act as ctrl and shift. In other programs or even in explorer they work as they should. 3DC doesn't seems to 'read' them. When I push 'shift' button it doesn't change to smooth mode. It's the same with 'ctrl'... it's not reversing brush function. I have mentioned about it to Mr. Andrew but I wonder is there anyone who has the same behavior of SN? Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted March 23, 2010 Report Share Posted March 23, 2010 Oh yes, what's interesting about the red lines is that they stay there after you Undo and they also stay in place in world space Video: http://screencast.com/t/MGY2MmU0Z Quote Link to comment Share on other sites More sharing options...
Javis Posted March 23, 2010 Report Share Posted March 23, 2010 Whoa those red lines are a bit annoying, lol. I'll just use 3.2.04 until they are ironed out. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted March 23, 2010 Report Share Posted March 23, 2010 I'll just use 3.2.04 until they are ironed out. Well it's only in the Increase tool so if you can avoid using that it's fine. I personally never use that anyway, so it won't bother me. Quote Link to comment Share on other sites More sharing options...
Advanced Member polyxo Posted March 23, 2010 Advanced Member Report Share Posted March 23, 2010 @Andrew : thank you ! Appearently the problem with SpaceNavigator remains the same, but I am confident that you will find a solution. I currently see no drifting on my machine. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 24, 2010 Author Report Share Posted March 24, 2010 I'm joining to above question. Those red lines appear only during 'increase' option enabled. My second (strange) thing that I'd like share with others and it is related to 3D Connection is the problem with buttons. In my Space Navigator they act as ctrl and shift. In other programs or even in explorer they work as they should. 3DC doesn't seems to 'read' them. When I push 'shift' button it doesn't change to smooth mode. It's the same with 'ctrl'... it's not reversing brush function. I have mentioned about it to Mr. Andrew but I wonder is there anyone who has the same behavior of SN? Uh oh. While making non-diving lines into voxel surface I forgot to remove debug info. I will re-upload soon. What about CTRL and SHIFT you should open Space navigator control panel and look how buttons are assigned. It is better to assign them to "Button 1" and "Button 2". Or you have intentionally set them as SHIFT and CTRL? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 24, 2010 Author Report Share Posted March 24, 2010 So I'm curious what this Upload Screenshot really does. Obviously it takes a screenshot and allows you to enter some text (though I don't understand the text fields exactly), but where does the screenshot go? Is it only viewable to Pilgway? I had a small bug and made a screenshot of it but I don't know what happened to it after I hit OK. Usually Coat opens browser window, it uploads screenshot to server and you are getting direct link to be placed on forum or somewhere. Edit: I found the reason why it can don't work sometimes. I will reupload soon. Quote Link to comment Share on other sites More sharing options...
Member Yann Posted March 24, 2010 Member Report Share Posted March 24, 2010 I currently see no drifting on my machine. polyxo, I suppose you're speaking of a PC ? on the 3 Macs I have been testing with 3.2.06 since yesterday, I get the same drifting behavior. It wont't necessarily appear right after launch, but it becomes very obvious if you increase resolution in the voxels room, for example. As a comparison, if I boot the same machines under Windows the drifting disappears. Quote Link to comment Share on other sites More sharing options...
Member Adamek Posted March 24, 2010 Member Report Share Posted March 24, 2010 Uh oh. While making non-diving lines into voxel surface I forgot to remove debug info. I will re-upload soon. What about CTRL and SHIFT you should open Space navigator control panel and look how buttons are assigned. It is better to assign them to "Button 1" and "Button 2". Or you have intentionally set them as SHIFT and CTRL? They are set as shift and ctrl. Mainly for 3DS MAX where they are used in the same way. In MAX all works just fine. Same settings in SN control panel doesn't seem to be recognized in 3DC. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 24, 2010 Author Report Share Posted March 24, 2010 Windows build reaploaded to solve red lines and screenshot issues. OSX - later. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 24, 2010 Author Report Share Posted March 24, 2010 polyxo, I suppose you're speaking of a PC ? on the 3 Macs I have been testing with 3.2.06 since yesterday, I get the same drifting behavior. It wont't necessarily appear right after launch, but it becomes very obvious if you increase resolution in the voxels room, for example. As a comparison, if I boot the same machines under Windows the drifting disappears. Can you record short video to show wrong behavior? Quote Link to comment Share on other sites More sharing options...
Advanced Member polyxo Posted March 24, 2010 Advanced Member Report Share Posted March 24, 2010 polyxo, I suppose you're speaking of a PC ? on the 3 Macs I have been testing with 3.2.06 since yesterday, I get the same drifting behavior. It wont't necessarily appear right after launch, but it becomes very obvious if you increase resolution in the voxels room, for example. As a comparison, if I boot the same machines under Windows the drifting disappears. Indeed. Win7 64 - Sorry, I should have mentioned that. Quote Link to comment Share on other sites More sharing options...
Member Yann Posted March 24, 2010 Member Report Share Posted March 24, 2010 Can you record short video to show wrong behavior? OK Andrew, I'll do it this afternoon. Quote Link to comment Share on other sites More sharing options...
Member Yann Posted March 24, 2010 Member Report Share Posted March 24, 2010 @Andrew : so I made a short movie showing together the screen (voxels room) and my hand on the SpaceNavigator. The drifting is very visible : http://cap3d.fr/3dc/3dc_sn_osx.mp4 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 25, 2010 Author Report Share Posted March 25, 2010 @Andrew : so I made a short movie showing together the screen (voxels room) and my hand on the SpaceNavigator. The drifting is very visible : http://cap3d.fr/3dc/3dc_sn_osx.mp4 Thank you! Now understood. Quote Link to comment Share on other sites More sharing options...
Advanced Member ifxs Posted March 25, 2010 Advanced Member Report Share Posted March 25, 2010 @Yann THANK YOU YANN!!!! for sharing the video that VERY clearly illustrates the issue... cant wait for a fix, and the use of my space navigator in 3DC!!!! That is EXACTLY the same behavior I experience as well in OSX 3DC. Quote Link to comment Share on other sites More sharing options...
Member Adamek Posted March 25, 2010 Member Report Share Posted March 25, 2010 Both Ptex and Microvertex. the Subdivision Progress hangs when I set "million of polys" level at 15. In 3.2.02 it works fine. In every version from 3.2.03 and above I have the same problem. It hangs in progress of 80%-90%. One core is non stop busy and leaving it for a wile or even longer doesn't make any change. What is strange it is not a big (or even middle poly) model. Just sphere with 15k tri quadrangulated to a few square polys. So, what processor makes so busy ? In version 3.2.05 appears a "Crash!!!" window. Message sent to Mr. Andrew. Quote Link to comment Share on other sites More sharing options...
Advanced Member ifxs Posted March 26, 2010 Advanced Member Report Share Posted March 26, 2010 One core is non stop busy and leaving it for a wile or even longer doesn't make any change. sounds like my every-day 3DC experience when in the vox room... :-( hope multi-threading support comes one day... also still hoping for 64-bit OSX 3DC one day.... anyone with any insight into this one... I'm having to boot into windows just to do many processes in the 64bit 3DC on windows... my 30day windows trial is about to run out in win64-3DC :-( Quote Link to comment Share on other sites More sharing options...
Member alonzo Posted March 26, 2010 Member Report Share Posted March 26, 2010 whats wrong here? also when I open a new document, the old lines are still there (Intel Mac - OS X 10.5.8 - Wacom) Quote Link to comment Share on other sites More sharing options...
Member Adamek Posted March 26, 2010 Member Report Share Posted March 26, 2010 Download 3.2.06 again. Version the same but without those debugging lines Quote Link to comment Share on other sites More sharing options...
Member Lawless Posted March 26, 2010 Member Report Share Posted March 26, 2010 Download 3.2.06 again. Version the same but without those debugging lines I did, the mac version has not been fixed. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 26, 2010 Author Report Share Posted March 26, 2010 Updated to 3.2.07 [beta] (Win+Mac, Linux - tomorrow) Changes: - Solved most longstanding problem - jagged strokes in paint modes (see http://bit.ly/aiw8u8 for reference). - Fixed incorrect work of ApplyUV command over some models especially in microvertex mode problem referred there - http://bit.ly/cylc4A ). - Upload screenshot bugs fixed I am aware of OSX Space navigator issue. It is not as easy to fix but at least it reproduced and fixing is in process. Quote Link to comment Share on other sites More sharing options...
Advanced Member ghib Posted March 26, 2010 Advanced Member Report Share Posted March 26, 2010 - Solved most longstanding problem - jagged strokes in paint modes (see http://bit.ly/aiw8u8 for reference). Unbelievable speed, Andrew, REALLY thanks for chasing this one so quickly. Will try this version soon and report. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted March 26, 2010 Applink Developer Report Share Posted March 26, 2010 Amazing update! I just had a quick test with the latest build and WAU! Ptex has been raised in new level. Very good speed. Thanks Andrew. Quote Link to comment Share on other sites More sharing options...
Contributor bwtr Posted March 27, 2010 Contributor Report Share Posted March 27, 2010 Amazing update! I just had a quick test with the latest build and WAU! Ptex has been raised in new level. Very good speed. Thanks Andrew. Is there a Ptex tute available please. Brian Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 27, 2010 Author Report Share Posted March 27, 2010 Is there a Ptex tute available please. Brian I think Javis will provide something soon Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted March 27, 2010 Applink Developer Report Share Posted March 27, 2010 There is still that Merge into scene with Ptex bug. Import -> Model for Ptex works and is a very fast. Quote Link to comment Share on other sites More sharing options...
Member Yann Posted March 27, 2010 Member Report Share Posted March 27, 2010 @Andrew : thank you so much and for your great reactiveness. Quote Link to comment Share on other sites More sharing options...
Member alonzo Posted March 27, 2010 Member Report Share Posted March 27, 2010 thanks... now its working Quote Link to comment Share on other sites More sharing options...
Advanced Member ifxs Posted March 27, 2010 Advanced Member Report Share Posted March 27, 2010 so many great bug fixes, thanks Andrew! Quote Link to comment Share on other sites More sharing options...
