• English
  • 3DCoat Documentation
    • Questions/Answers
    • Training Tutorials
    • Questions/Answers
    • Space Bar Menu
      • Painting Modes
Custom documents folder
1035 views 1
  • On Windows
  • On Linux
On Windows
You should define environment variable “COAT_FILES_PATH” with full path to your custom documents folder.
By default “3DCoat” stores user files inside folder “This PC > Documents > 3D-CoatV48” under Windows and inside folder “HOME > 3D-CoatV48” under Linux/macOS.
You can define environment variable “COAT_FILES_PATH” with full path to your custom documents folder. Under Windows do the following:
START > Settings > System > About > System info > Advanced system settings > Environment Variables… > System variables or User variables for XXX > New… >
Variable name: COAT_FILES_PATH
Variable value: C:\WORK\My-Data\3D-Coat (place your path here)
No need to restart your PC. Just run 3DCoat.
On Linux
Under Linux please read section Environment variables under Linux and under macOS read section
Environment variables under macOS inside this document:
http://www.3d-coat.com/~sergyi/LinuxDocs/FServer.pdf
CustomDocumentsFolder-1Download
Also please read section with title “Share the same 3DCoat installation between multiple users” in the
document above
1 Yes  No
  • Space Bar Menu
Folders Structure
Different Forms of “Resolution”
